Results 1 to 9 of 9
Thread: 2.2 Ecotec e37 stand alone
    Feb 2012
    Default 2.2 Ecotec e37 stand alone
    Can i use efi live to disable or apply patch to disable vats and bcu etc on 2008 cobalt donor car to work stand alone in sandrail? Can i later (as standalone ecm) tap into whatever necessary wires and modify programming for whatever reason? Possible to use to control turbo setup on down the road? noob here, obviously
    Yes EFILive does support VATS disable on the E37 ECM, as well as disable DTC's for things that might be missing on the sandrail vs Cobalt.
    As far as Turbo support, you are in luck, most of GM's ECM from 2006+ are already able to support boosted engines (E37 included). Whilst there is no wastegate controls, you could at least control fuelling in to boost (up to 255kPa MAP).
    Feb 2012
    Will a fairly intelligent noob be able to accomplish this? Im assuming i can obtain some wiring diagrams / pinouts from alldata or somthing...
    To disable DTCs and VATS is about 20 mouse clicks then wait 30 seconds for a flash. No need to work with the wiring (unless you need to get a stock harness to work without a starter relay/etc).
    For turbo support you will be able to control fueling and spark under boost without a problem, imagine thats down the road a little, but shouldnt be too difficult.
    Feb 2012
    so engine harness plugs into j1 or j2 haha cant remember right now. But the other needs to be hooked up to constant power, switched power, gnd , and lan wire or whatever right? Lan wire would be hooked up to one in the efi live cable right? i plan on cutting connector off car and wiring just what i need to it (fused). Dont really plan on running fuel pump or cooling fans off ecm unless someone thinks i need to for some reason, could very easily run start signal manually as well, but i read some stuff about that working too...
    Feb 2012
    Does anyone have an e37 pinout to share??
    Mar 2009
    all data has all the prints for this application. Questions? pm me or give me a call,Steve 909 910 3867
    Feb 2012
    well actually ive decipered the wiring, without a pinout or schematics, ive got it down to about four hookups, so im pretty happy, if alldata were free id for sure go take a look cause i cant get cluster to work without bcm but dont know if its possible anyway, thanks efiharness. Im probably just lucky i havent burnt anything up getting to this point.
    Mar 2009
    What are you missing
  1. Ecotec files
    By slows10 in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: January 10th, 2011, 10:16 AM
  2. unsupported ecotec pcm
    By Gregs in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: August 24th, 2010, 04:23 PM
  3. Holden Vt V6 ecotec - help
    By andy_h83 in forum EFILive V4
    Last Post: May 6th, 2010, 08:51 AM
  4. Anybody have a stock file from an ecotec 2.4L?
    By antivenom in forum E37, E38 & E67 PFI ECM's
    Last Post: June 3rd, 2007, 03:40 PM
  5. Ecotec in a miata
    By finiata in forum General (Petrol, Gas, Ethanol)
    Last Post: November 22nd, 2006, 10:43 AM
