Results 1 to 10 of 17
Thread: Open Loop VE IAT Multiplier Values
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default Open Loop VE IAT Multiplier Values
    What values is everyone finding suits the B0014 Table.
    I think i may have been thinking i would have to correct the wrong direction? So i have set mine back to 1.00 at the moment.
    Can some people share their numbers for this table.
    Oct 2004
    I have had a brief play with this a while ago.. All mine are currently set to 1 at the moment as well.
    The numbers will likely be different for everyone. For example, if your VE is dialled in at say 30*C IAT and someone else's is dialled in at 20*C IAT then the point at which your B0014 table will be 1.00 is different to start with.
    Basically my approach to this was to get my VE dialled in at a particular IAT temp range (i.e >= 25 & < 35 would be working in only the 30*C IAT cell). Once that is done I made a map that mirrored the B0014 table and then used a filter to select Fuel Trim 22 cells (cause they should be more stable than decel etc.) and used the averaged BEN factor as the data. My thought was that I could copy this data straight into the table because hopefully the 30*C IAT cell would be 1.00 and say 20*C IAT might be 0.98 ad 40*C IAT might be 1.01, all for examples.
    Hope that helps?
    Andrew
    EFILive Crew
    I have mine set to 1.00 as well, it seems to be an issue when you hit 50+degC IAT's, i.e, like a blown car.
    Oct 2004
    Quote Originally Posted by GMPX
    HA! I can get 50*C IAT sitting at a light for a while, and this is in Auckland let alone somewhere real hot (like Australia). I previously had a metal intake tube as well and actually recorded IAT temps in excess of 70*C IAT .
    I think my next mod is going to be an OTRCAI, the cam is just going to have to wait
    Andrew
    EFILive Crew
    Nov 2003
    Talking
    I have my table set to stock also. I read one member changed his by 1% every 10 d.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Nov 2005
    Someone quoted that for every 11*F changes air density 1% then every 10 deg C has a change of 1.6% density. So maybe the number that we need is going to be about 1.6% difference every 10 degrees.
    I have mine set at 2% every 10 deg C at the moment and its getting close - but i think i now need to tweak the ECT multiplier table as well.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    Quote Originally Posted by Tordne
    Ah, you still have the factory heat box.....err I mean air box?.
    OTRCAI is good, but it doesn't 'sound' as nice as a cammed motor!.
    Oct 2004
    I actually have a Kosteci airbox with a K&N pod filter, and now a carbon fibre/fibreglass intake tube. Actual air deliver is really good and possibly won't by hugely improved upon, but the IAT temps are killing me. I am recording into the 50*C IAT range and it just takes ages for the IAT's to recover, and they usually only recover to as low as perhaps 35*C. Ambient temp in Auckland is approx. 25*C, so there is a huge difference.
    Prior to the carbon intake tube I was logging temps into the 70*C range .
    Hopefully I'll be getting a OTRCAI soon (next few weeks), just trying to decide which one.
    Andrew
    EFILive Crew
    Lifetime Member McRat's Avatar
    Nov 2005
    Just rambling about IAT's in general.
    Often the true IAT has nothing to do with what the sensor tells the engine. Sitting on the line in the summer, a Z06 will report over 150degF to the engine when the air going into the engine is only 80 deg.
    If cannot relocate your IAT sensor outside the engine bay, you should at least zero out any effects that are in the "stupid range". Anything over 90 degF should probably be ignored. For racing, I zero out all effects of IAT.
    The difference it made in 1/4mi ET was .48 seconds.
    Nov 2005
    Doesnt IAT and ECT effect the VE tables effects anyway? Maybe im wrong but i thought that was we needed the correction tables??
    You are right the IAT heat soaked can say the airs much hotter than it really is. This is an issue.
    Oztrack
    www.oztrack.com.au
  1. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  2. program is changing open loop to close loop
    By louis in forum General (Petrol, Gas, Ethanol)
    Last Post: November 7th, 2007, 06:38 AM
  3. Open loop or semi open loop still?
    Last Post: October 18th, 2007, 03:46 AM
  4. Semi-Open Loop Vs Just Open Loop
    By BowlingSS in forum Custom Operating Systems
    Last Post: April 14th, 2006, 05:25 AM
  5. Open Loop SD VS Closed Loop SD Advantages???
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: August 4th, 2005, 12:25 PM
