Tried a dozen times to read a kodiak today,
Message is:
"Cannot merge calibrations with CPU system file: C:\Program Files\EFILive\V7.5\Configuration\Z00.ext"
Any ideas.
Message is:
Any ideas.
Did you use the "Check for Updates" option in the Windows Start menu? If so, uninstall EVERYTHING and reinstall the latest RC9 stuff from this thread: Release Candidate 9 Feb 09 2012
If not, then not sure. I think the *.ext files were used with Duramax stuff, but not sure what they do/did. Did the error happen before or after the read attempt?
Got it figured out, the ecm was a bench read, was out of a wreck and was actually an LMM ecm and not an LBZ ecm.
Read out fine once that was resolved.
