Results 1 to 3 of 3
Thread: Anyone have trouble with vats relearn on LMM
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Anyone have trouble with vats relearn on LMM
    Hey guys,
    Sent an ECM to a guy in new Mexico and he couldn't get it to relearn to his truck... He sent it back and I sent him another one.... He still can't get it to work.... I've never had an issue with any other ECM's I've sent. Is it common or is it likely something he's doing wrong? I emailed him detailed instructions
    Peace Through Torque
    www.PunisherPerformance.com
    Jun 2008
    I'm starting to think it's the ol' programming injector flow data issue.....
    I've got another ECM here that can be shipped out tomorrow if I can get this issue sorted out...
    On my V2 when I try to "read GPM inject" it says "no data found" when I choose "read ECM inject" it seems to work..... which one should I be using in this instance? Seems like it used to be "read GPM inject" and then "Program ECM inject"
    Thanks!
    Jun 2008
    Any advice is still welcome, although after digging in a little deeper I've basically come to the conclusion that I need to:
    1.) disable anti theft, set relearn to 1
    2.) Program injector flow rate into ecm
    3.) Program new vin into used ECM (already had done that)
  1. 2010 LMM VAT relearn
    Last Post: March 17th, 2011, 04:05 PM
  2. Vats
    By Yortt in forum General (Petrol, Gas, Ethanol)
    Last Post: December 5th, 2010, 12:21 PM
  3. LMM: VATS and new ECM
    Last Post: November 22nd, 2010, 10:01 AM
  4. Replies: 3
    Last Post: August 27th, 2010, 03:24 AM
  5. LBZ/LMM VATs
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 22nd, 2007, 09:56 PM
