Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Handling more than stock boost ?
    Ok, that answers my question if the log actually maxxed or if you just needed to rescale the dash. Interesting to know about the max pressure, most gas guys never push more than 255kPa!
    Apr 2012
    Wow, all the turbo cars i know don't even hit 100Kpa! My turbo set up will push a little over 515Kpa, so I would like to have a sensor that goes up to 600 at least so I'm only using 80% of the gauge.
    2007.5 Dodge 3500 - some power mods with a 48re behind it
    Oct 2011
    Twins will make 70 PSIG or ~85 PSIA.
    Apr 2012
    AEM makes a 7bar (100psi) map sensor at 0.5v to 4.5v, the only thing that would confuse the ECM would be the limiter of 58psi on my truck compared to the 5.9's at 100psi. Is there any way to tell what the hard limiter is on a 6.7L? The EFI soft limit seems to be 58psi.
    Oct 2011
    Digikey has Honeywell 7 bar absolute pressure sensors for $90. Way better than those plastic things.
    http://search.digikey.com/scripts/Dk...100PAAAX&v=480
    I don't think there is a hard limiter. The ECM supplies 5V and takes in whatever voltage the sensor gives back, 0 to 5V. Rescale and let it rip ?
  1. Replies: 2
    Last Post: January 30th, 2012, 09:08 AM
  2. Boost timming AFR ??? GT4294 on stock LS1
    By fezz57 in forum Gen III V8 Specific
    Last Post: May 13th, 2010, 05:51 PM
  3. No Boost
    By eclispe1 in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 18th, 2008, 06:21 AM
  4. Use MAF for off boost/2 Bar SD when in boost
    By Earl H in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: May 24th, 2007, 12:58 PM
  5. Competition Mode/Active handling/Traction Control
    By Beer99C5 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 4th, 2006, 08:54 PM
