Results 1 to 10 of 12
Thread: Converting my 04.5 to an 06 ECM ?
    Oct 2011
    Default Converting my 04.5 to an 06 ECM ?
    I have an 04.5CR swapped into a Ford.
    Any advice on converting it to an 06 ECM so I can run EFI Live ? I'd also really like access to the CAN bus for a few other things too.
    Would an 06 ECM need a different engine harness ?
    Are all the sensors the same between the two engines ? I know the injectors are different, but I assume we can overcome that with changes to the duration table ?
    Senior Member DODGE74's Avatar
    Oct 2011
    Why don't you just hang tight for a few more months instead of spending a bunch of unnecessary money. Efi live is just around the corner for you guys.
    06 QCLB, DRW
    Single pump
    Single turbo
    EFILive 772hp 1398tq
    gordon@innovativediesel.com
    Lifetime Member FUBAR's Avatar
    Feb 2011
    I think he wants some of the features of the CAN system for the rest of the truck.. so it sounds like depending how hard it would be would be the deciding factor if he pursues it or not.
    06 LBZ, EFILive
    Senior Member TexasCummins's Avatar
    Jul 2011
    I would think you would have to upgrade many other components as well, seeing as how on the CAN network each component is its own computer (cluster, radio, overhead module, etc).
    EFI Live - The Smarter way to tune!
    2006 Ram 2500 4x4
    Oct 2011
    Quote Originally Posted by FUBAR View Post
    Ahh, you may be right.
    06 QCLB, DRW
    Single pump
    Single turbo
    Oct 2011
    Quote Originally Posted by TexasCummins View Post
    The engine is swapped into a Ford, so none of this stuff is present. All I need it to do is run the engine.
    Oct 2011
    Quote Originally Posted by DODGE74 View Post
    OK, I can do that.
    I asked the guys in Cummins Beta about such a swap, on a Dodge RAM it sounds like a major deal, new engine wiring harness, and many other things that make it a major drama. Of course if it's not in a RAM then that probably does simplify things a bit.
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    We are doing the same thing with our drag truck currently. there are really only 8 wires that you need, but you will have to have a complete 06-07 ecm and harness to make it work.
    Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
    EFI Live Cummins Beta Tester
    Duramax and Cummins Tuning
    423-506-7427
    From what I understand the problem is the TIPM (I think that is the right name), it sends some specific messages on the CAN bus to the ECM that of course aren't there on an early chassis.
  1. Converting tunes to DSP
    By rjwesleyiii in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 24th, 2010, 04:45 PM
  2. Converting to drive by cable.
    By Jon in forum Gen III V8 Specific
    Last Post: March 25th, 2010, 05:02 AM
  3. Converting EOPS
    By Ninety8C5 in forum Do you want to be a Beta Tester?
    Last Post: May 20th, 2009, 10:45 AM
  4. Converting Scan data
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 8th, 2006, 10:41 AM
  5. Converting from HPTuner
    By Rod in forum General (Petrol, Gas, Ethanol)
    Last Post: June 15th, 2006, 10:18 AM
