Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Truck feels fast for a little while then...................
    Senior Member JustinD's Avatar
    Jul 2009
    Default Truck feels fast for a little while then...................
    I have been having issues with my truck for a while now, did a new LB7 CP3 and LBZ regulator along with my new II turbo, then we found 3 injectors be to be bad, replaced those, truck felt great for about 3 hours, then started to feel sluggish, dynoed it 2 days after I got it back, made 523 which I understand is about normal for my setup, but it feels sluggish now?? I changed tunes and it felt great again but same thing it was short lived. I am going to try to reset TAPS later tonight and see if that works??? Any ideas?? Any help would be greatly appreciated, I am very close to just getting rid of it and buying a 1500 with a 5.3 no issues!!!
    2001 Chevrolet K2500HD Duramax
    Suncoast SCIV 1056
    Kennedy twin lift pumps
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    A few more go fast/truck pulling goodies!
    Tuned with EFI
    12.65 @ 107 1.71 60'
    Jul 2009
    I have noticed that in my log I only see 20* minjt but my tune shows 24.8-32.8 in that range on my injection timing base C table?? What could be limiting me?
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Lifetime Member LB72004's Avatar
    Dec 2011
    how old is the fuel filter, did you try changing it? try logging desired fuel pressure vs actual, this should give you an idea if it is fuel related. did you rescale the LBZ regulator?
    i don't think that resetting the TAPS will help. resetting the TAPS will just reset the shift time back to factory settings and may make it shift funny for a little while. if you do, take it easy on the transmission until it settles down.
    Jason
    Dec 2011
    add your main timing C to your pilot timing D and see if it is being limited by {B0921} injection timing max
    Lifetime Member Dmaxink's Avatar
    Nov 2009
    Post up the datalog and lets go from there
    -Kory
    I'm out of ideas? Nah trick... When in doubt, 0xFFFF it out!
    http://www.PPEI.com/
    Jul 2009
    Thanks guys!!! I have been work with Trent from EPR I think he may have it narrowed down but I appreciate all the help!!!!!
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Dec 2011
    you don't want to go there. hope you get this one fixed.
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Jul 2009
    Quote Originally Posted by LB72004 View Post
    HAHAHAHA! Thanks!!
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jul 2009
    Still having issues...........
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
    Jul 2009
    Can I log Crank and cam sensors with EFI? My timing is being limited, could it be possible the crankshaft pos sensor can get a screwy reading and act like this???
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
  1. Need help fast truck wont start
    By way2much_01 in forum Petrol / Gas
    Last Post: August 5th, 2011, 10:46 AM
  2. trans feels like slipping after doing a burnout
    By steve40 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 12th, 2009, 03:09 PM
  3. Truck feels sluggish at part throttle
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:52 AM
  4. Car feels really flat initially
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 05:23 PM
