Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Truck feels fast for a little while then...................
  1. #21
    Lifetime Member LB72004's Avatar
    Dec 2011
    the rattle is what worries me. if the Baro is reading low it will run on the high altitude timing map which may rattle some at lower altitude. it could be fuel related too. try coping Timing map C to Map B and Map A and saving it to a new file. see if that take care of the rattle. right now the logs show the Baro & Boost having the same slope, boost and baro go up and down together. this will alter the timing. double check the baro sensor and also, as silly as it may sound, make sure the the harness connectors are not swapped with another or something like that
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
  2. #22
    Dec 2011
Name:	Baro & Boost Log.JPG
    check out one of my logs. boost goes up to 34 lbs, baro stays at 14.6 lbs. something is not right with your baro sensor.
  3. #23
    Senior Member JustinD's Avatar
    Jul 2009
    Ok, found the rattle culprit, I had a boost leak. Drivers side lower boot was leaking, bought a PPE boot and its 100% better, as I log it and watch mm3 it sometimes goes to 126.9 or higher but sometimes when you lean on it it shows only up to 98mm3 or so?
    2001 Chevrolet K2500HD Duramax
    Suncoast SCIV 1056
    Kennedy twin lift pumps
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    A few more go fast/truck pulling goodies!
    Tuned with EFI
    12.65 @ 107 1.71 60'
  4. #24
    Mar 2009
    Any luck on figuring out the issue? I could look at the tune for you if you would like?
    2002 Chevy Duramax with a few supporting mods.
  5. #25
    Jul 2009
    Seems better now, but I still notice the commanded mm3 will be say 120-124mm3 and it achieves 98.3mm3? is it just on its way up? I do see 126.9mm3 as my max now. Seems like it gets to 126.9 and then slowly falls off? Not sure if I'm ok now?? Anyone want to take a look at my logs for me?
    Suncoast SCIV 1056
    Billet pick up
    MBRP 4" exhaust
    Air intake horn mod
    ARP head studs
    Tuned with EFI
  1. Need help fast truck wont start
    By way2much_01 in forum Petrol / Gas
    Last Post: August 5th, 2011, 10:46 AM
  2. trans feels like slipping after doing a burnout
    By steve40 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 12th, 2009, 03:09 PM
  3. Truck feels sluggish at part throttle
    By Aint Skeered in forum General (Petrol, Gas, Ethanol)
    Last Post: June 9th, 2007, 05:52 AM
  4. Car feels really flat initially
    By Tordne in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 05:23 PM
