so i have had this problem for a while. when i first got my truck several years ago i had to replace my BCM as the headlights where stuck on. i found a used one online with the same part number and everything seemed good. the only problem i have noticed is the OD lock out wont activate. tow haul works great so i know the wires are fine.
is this just a BCM programming thing? i thought that all of the 04 LB7s had the over drive lock out function programmed in them. is it possible that the some BCMs where used in Gassers and had no OD LO and this is what i happened to use? was looking forward to doing the 5 speed manual gear select upgrade and will need this function to work to do it.
anyone have any other ideas for me to check before i try another BCM or, gasp!!! go to the dealer for programming?
thanks
Jason
