Results 1 to 5 of 5
Thread: Problems with v2 liscense
    Dec 2007
    Default Problems with v2 liscense
    Ok when I hook up my V2 I can go through its menu & it shows to have 1 liscense available. When I bring it up in the tune software none of the vins show up. I went ahead & purchased two additional vins & niether activation codes work. The tune software reads the serial Number of the V2, so its communicating. I need to get this working. ASAP. Please help.
    Which V7/V8 software build version do you have installed...?
    Which V2 firmware version/date...?
    I pm'd Tech Support.
    Dec 2007
    Thanks for the quick reply.
    software 7.5.6 Build 133
    Firmware Version 2.07.22 Date Aug 23 2011
    Oct 2004
    There was an issue quite a while back where due to a FlashScan device running firmware version 2.07.05 or later and having older EFILive software installed. The issue occurred due to a licensing structure change that was introduced in 2.07.05 to accommodate the upcoming Cummins release. When you are not using the latest software when you query licenses in the V7.5 Tune Tool it returns none. This would also effect flashing as it is not able to read the allocated licenses either.
    The solution should be simple. Just download and install the latest V7.5 and V8 software, and update the FlashScan V2 device firmware. There are more details in these knowledgebase articles:
    - Software: http://support.efilive.com/kb_articl...5404-IJZV-0820 (DO NOT perform the Check for Updates as there are issues with that presently)
    - Firmware: http://support.efilive.com/kb_articl...7243-SFGL-2949
    Andrew
    EFILive Crew
    Dec 2007
    Thanks, that took care of the problem. Thank you for the quick resolution.
  1. Auto Cal Liscense Info
    By Mike@Vengeance in forum AutoCal
    Last Post: November 11th, 2011, 07:54 AM
  2. My new liscense code does not work???
    By nitrorocket in forum Purchase and Shipping
    Last Post: August 24th, 2008, 09:07 AM
  3. 03 truck, PO300 and Liscense problems
    By PladdPezzPunk in forum Gen III V8 Specific
    Last Post: October 6th, 2007, 10:14 AM
  4. I am waiting for a liscense
    By hpy540 in forum FlashScan V2
    Last Post: August 28th, 2007, 10:59 AM
  5. Having some Problems with LM-1
    By mwalls54 in forum General
    Last Post: January 21st, 2006, 09:05 AM
