hello guys as i stated in one of my other threads i recently purchased an 03 LB7 to match up with my 05 LLY , it had a raptor 150gph lift pump on it, and i have paper work showing the oem injection pump was replaced about a year and a half ago.... has truck running in my driveway flipped it over to hot tune and it was just at idle, truck stalled, turned key back on noticed i didnt hear the lift pump engage so i flipped switch back to stock, hit the primer under hood took a couple tries but it fired up. left in on stock tune just as pulling in my driveway it acted like it was running out of fuel then stalled, would not start back up, removed fuel filter filled in with fuel reinstalled it. It fired back up for a few seconds prob till filter was drained, I assume the worst Raptor pump burned out? any body heard of that before what would cause that or are they noted for that? and also assuming my stock injection pump is ruined aswell, any input ideas would be great thanks
