Hi Cyborg, welcome to the forum
-Thanks!
How is your LC-1 wired...?
-I'm using a serial cable, is that what you are asking? Both the EFILive and Innovate serial cables were female so I connected them with an adapter. Maybe I'll try reversing the adapter just in case it's directional. If it would be helpful I could take a pic of how the other wires are connected under the dash.
Do you have FlashScan V1 or V2...?
-V2
Which wideband pids are you using...?
- DESCRIPTION CAPTION UNITS SYSTEM CH PARAMETER
Y Base Efficiency Numerator 1 - Dyno BEN_DYNO factor WO2-Serial 0 CALC.BEN_DYNO
Y BEN Factor Bank 1, Serial Wideband, LS1 style BEN1 factor WO2-Serial 0 CALC.BEN1
Y BEN Factor Bank 2, Serial Wideband, LS1 style BEN2 factor WO2-Serial 0 CALC.BEN2
Y External Wideband AFR WO2AFR1 AFR WO2-Serial 2 EXT.WO2AFR1
Y External Wideband AFR WO2AFR2 AFR WO2-Serial 2 EXT.WO2AFR2
Y External Wideband EQRatio WO2EQR1 EQRatio WO2-Serial 2 EXT.WO2EQR1
Y External Wideband EQRatio WO2EQR2 EQRatio WO2-Serial 2 EXT.WO2EQR2
Y External Wideband Lambda WO2LAM1 Lambda WO2-Serial 2 EXT.WO2LAM1
Y External Wideband Lambda WO2LAM2 Lambda WO2-Serial 2 EXT.WO2LAM2
Y External Wideband Sensor State WO2ST1 WO2-Serial 2 EXT.WO2ST1
Y External Wideband Sensor State WO2ST2 WO2-Serial 2 EXT.WO2ST2
-Since I really don't know what I'm doing, I just selected all the PIDs under the System drop down box:WO2-Serial
Which V7 software build version (do Help->About)...?
