Results 1 to 3 of 3
Thread: Vat relink not working code $33
    May 2009
    Default Vat relink not working code $33
    I tried to use the tune tool to do and vats relink on an 03 lb7 after installing a used ec m to replace 1 that was fried and it would not work gave error code 33 and sometimes I would hit the button and it would say ec m not secured ec m not secured then give me the error code another time it went through and said trying to initialize I think 3 or 4 times then error code I did not try the manual method as I did not have time so I disabled the vats for now in ecm
    I am using pre release 9 and have all the firmware and bootblocks updated
    If I recall the VATS relearn is really fussy on the LB7, best bet is the IGN on for 30 minutes trick.
    So what you need to do is:
    Turn IGN on, leave for 10 mins (make it 12 to be sure).
    Turn IGN off for 30 seconds.
    Then start the truck, at this point (yes 30 mins in total) the VATS should have done an automatic relearn.
    Or to make it easier, just change {G0302} Relearn Timer from 600 Seconds to 60 seconds, then you'll only need to wait 1 minute for each key on instead of 10.
    May 2009
    Ok thanks ross, thats really the first time I'd used it as this was my first ecm failure.
  1. VAT relink feature
    By killerbee in forum Duramax LLY
    Last Post: December 30th, 2011, 02:13 PM
  2. Is a licence needed to do a Vat Relink
    By Eric in forum Gen III V8 Specific
    Last Post: August 19th, 2009, 10:23 AM
  3. Do I need to do a VAT Relink ???
    By Ninety8C5 in forum Gen III V8 Specific
    Last Post: May 27th, 2008, 02:44 AM
  4. VAT Relink
    By Biggsy in forum Gen III V8 Specific
    Last Post: October 10th, 2007, 09:40 PM
  5. Change Vin # and VAT relink
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: August 23rd, 2007, 01:14 PM
