Ok the fuel gauge moves but it is reporting about 20-25% higher then what it should be in efilive. The volts at full is 2.7 volts is there a conversion from volts to pwm so I can set this this gauge better?
2018 Colorado ZR2 Diesel
1998 Firebird Transam A4
Installed: 4l80e with yank 3200 stall, mwc 9in 3.00 gear wavetrac 3in off the sides, wattslink, PCM upgrade, Strano springs, 24 way QA1 front/rear, stainless steel brake hard lines, pst carbon fiber driveshaft, Boyd Harm rims 18x12/18x10(not minitub), kooks 1 7/8 full lenght headers and true dual exhaust, Zainoed
Hello Cool28,
What type of fuel sender (or vehicle) are you working with, and what PCM and calibration are you using ?
I believe GM has used at least 3 general types of fuel sending units over the years:
- 0 to 30 Ohms (empty - full)
- 0 to 90 Ohms (empty - full)
- 240 to 33 Ohms (empty - full)
The above values may not be exact, but represent the general range.
Regards,
Taz
This is a 98 transam with a 02 PCM. I been uploading numbers and it looks like 116 for 100% full on gauge is close to efi 100% but after that it doesn't add up. I had 4 gallons left in the tank and it showed half full yet lol
Hmm well I don't know it must creep up when running cause the cal numbers are right just checked it. Maybe my sender is going
I'm not that familiar with 1998 LS1-A systems ... I recall a thread somewhere that discussed using an 2002 Express (I think) Fuel System segment when upgrading to a 2002 OS ... may have been a Corvette thread ... not sure if it is applicable to your Camaro.
Regards,
Taz
