Results 1 to 5 of 5
Thread: going Custom OS
    Lifetime Member ZL1Killa's Avatar
    May 2005
    Default going Custom OS
    I have a 2001 trans am and i'm still using the normal OS : 12202088
    my VIN # is 2G2FV22G312135527
    on page 3/4 of the tutorial it is talking about finding EFILives custom OS that matches "your" PCM's current OS....
    now i see it describes 01 02 and 03.. but on page 4 i see my number
    12202088 and 012500xx for the EFILive custom OS
    how/where or what is this number and where can i find it? lol.
    I downloaded the custom OS for 2001 from the download page here. what is this 012500xx number?
    01 T/A WS6 #4984 STOCK 342HP and 352TQ [/b]MODS:Too many to list, PM...funny rear mount.. father/son build.
    [Quote :ur car is sneezing!!!!]
    I KNOW KUNG FU.
    My STS build: http://www.ls1tech.com/forums/showthread.php?t=631954
    453HP 475TQ @6psi
    .....CAM'd, IC'd, and 7psi'd #'s coming.....
    Lifetime Member MN C5's Avatar
    Mar 2005
    The XX identifies the custom OS you want to install. On page 3 of the tutorial it gives you the feature set of each Custom Operating System
    i.e. 01 Dual Spark Speed Density Enabled.
    So in your case if you wanted that COS you'd load from the custom bins 01250001 replacing the xx with 01 or 02 or 03 depending on the COS you wanted.
    Read the whole tutorial it will help.
    May 2005
    i had not unzipped the COS to see that they contain multiple files iwth 01, 02, and 03 yet. That tutorial is a little confusing on that. I understand now; and i have already read through it twice. Still sitting here and reading to understand. I'm at least doing my own reading, lol. I'm trying...hahaha
    I KNOW KUNG FU.
    453HP 475TQ @6psi
    Oct 2004
    Quote Originally Posted by ZL1Killa
    If ya need a hand left me know.. I have extensive experiance installing custom OS's, god knows I've done it enough on mine.
    Andrew
    EFILive Crew
    May 2005
    thanks man, pm sent. I'm going to first get my SD tune right so that my car is running right and I have something GOOD to go back to; I will probably go to COS this weekend after a good tune is finished.
    I KNOW KUNG FU.
    453HP 475TQ @6psi
  1. Two PCM's with same Custom OS HELP
    By superspeed in forum Gen III V8 Specific
    Last Post: February 1st, 2009, 02:45 PM
  2. custom OS with efi v1
    By dsmlights in forum Custom Operating Systems
    Last Post: December 5th, 2007, 07:28 PM
  3. Why LM-1 Custom PID???????
    By 2002_z28_six_speed in forum General
    Last Post: June 4th, 2007, 12:52 AM
  4. Custom Os???
    By FFP in forum Custom Operating Systems
    Last Post: December 7th, 2006, 01:11 PM
