You can vary the AFR by from 15.2 to 13.4 at part load with vary little change in power output on the dyno , fuel consumption changes heaps though.Originally Posted by ringram
What you find is its not bank related the variance in fueling but cylinder efficiency at different loads as speeds s the airflow changes in the manifold , not really a issue at part throttle or naturally aspirated but when blown I can detect a huge difference hence we tune to the leanest cylinder so as not to cause a breakage , when looking at a O2 you are just seeing a average of that bank.
Closed loop O2 cycling will also be different between 2 )2 sensors hence you can have a slightly different trims , the LTFT's are just trying to keep it in the aveage 14.63 area and overshoot and undershoot to do it , this can be by a different amount as well.
Personally tuned properly and maintained a car will always run better and more efficiently in open loop than in closed loop , the closed loop masks poor tuning and differences between engines and environments
