how do I remove existing tunes and save to my computer, for purposes of trying other tunes. I've purchased many tunes and would like to try other ones.
As long as its from the same tuner all you need to do is download and install v8.1 and open up EFILive explorer and look at the tune folders. You'll see the tune files pop up in the box which you can click and drag to your desktop and delete it from the box. Then copy and paste the new tunes into the box. Keep in mind the autocal can support four tunes total.
Dan's Diesel Performance
www.dansdieselperformance.com
Ok would I beable to look at those tunes too. I'm kind of interested in it.
oh I see. thanks
Once I copy the tune file into the tunes folder for the AutoCal device, is there something I need to do to send the tunes to the AutoCal then? Thanks!
Peace Through Torque
www.PunisherPerformance.com
Just have the autocal plugged in to your laptop. The autocal must be linked to your V2. You'll save to tune for remote flashing and then click and drag into the autocal tune folder of your choice. That's it.
Thanks Dan,
only question is this.... all my devices are linked and stuff, but when I open EFILive Explorer, I can drag the tune file into place, but the only folders I have are Scan, Tune>read, I think, I don't have any other folders to drag the tune file into.... not sure what I'm doing wrong.
Thanks again man
Right click on the tune folder and select New Folder and name it the name of the tune. Then double click that folder and drag your tune into that big white box to the right of the folders.
Okay good deal, thanks for the fast reply!
