Results 1 to 10 of 15
Thread: change and save tunes from autocal
    Mar 2012
    Default change and save tunes from autocal
    how do I remove existing tunes and save to my computer, for purposes of trying other tunes. I've purchased many tunes and would like to try other ones.
    Lifetime Member dansdieselp's Avatar
    Apr 2009
    As long as its from the same tuner all you need to do is download and install v8.1 and open up EFILive explorer and look at the tune folders. You'll see the tune files pop up in the box which you can click and drag to your desktop and delete it from the box. Then copy and paste the new tunes into the box. Keep in mind the autocal can support four tunes total.
    Dan's Diesel Performance
    www.dansdieselperformance.com
    Mar 2012
    Ok would I beable to look at those tunes too. I'm kind of interested in it.
    You wont be able to see the tunes.
    Mar 2012
    oh I see. thanks
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Once I copy the tune file into the tunes folder for the AutoCal device, is there something I need to do to send the tunes to the AutoCal then? Thanks!
    Peace Through Torque
    www.PunisherPerformance.com
    Apr 2009
    Just have the autocal plugged in to your laptop. The autocal must be linked to your V2. You'll save to tune for remote flashing and then click and drag into the autocal tune folder of your choice. That's it.
    Jun 2008
    Thanks Dan,
    only question is this.... all my devices are linked and stuff, but when I open EFILive Explorer, I can drag the tune file into place, but the only folders I have are Scan, Tune>read, I think, I don't have any other folders to drag the tune file into.... not sure what I'm doing wrong.
    Thanks again man
    Apr 2009
    Right click on the tune folder and select New Folder and name it the name of the tune. Then double click that folder and drag your tune into that big white box to the right of the folders.
    Jun 2008
    Okay good deal, thanks for the fast reply!
  1. Converting DSP2 tunes to DSP5 Tunes
    By BlkMax in forum Duramax LB7
    Last Post: March 6th, 2009, 10:14 AM
  2. some fields just will not save??
    By slopokegtp in forum General (Petrol, Gas, Ethanol)
    Last Post: July 31st, 2007, 07:39 AM
  3. Would unlocked tunes encourage you to pay for more tunes?
    By ringram in forum General (Petrol, Gas, Ethanol)
    Last Post: November 11th, 2005, 01:09 PM
  4. Can't Save
    By dbaxter_ss in forum General
    Last Post: May 28th, 2005, 02:22 PM
