Results 1 to 9 of 9
Thread: 2012 CTS-V - No Tune found
    Sep 2010
    Default 2012 CTS-V - No Tune found
    Tried reading the factory T43 cal from a 2012 CTS-V and was given a message that no calibration found and to e-mail the file to support. I did not hear anything back from support and need to tune this car tomorrow
    Paul Meister
    EFI Calibrator/Managing Member, Torq Speedlab, LLC
    Specializing in late model Ford, GM and Dodge EFI Calibrations
    SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
    What is the operating system number of the tune file from the T43? Is it 24261871?
    OS number 24261871 was added in the RC9 software available here:
    http://forum.efilive.com/showthread....-9-Feb-09-2012
    Sep 2010
    Awesome. Thanks for the help!
    Paul Meister
    Sep 2010
    Went to flash the PCM and the car will not start. V2 shows P0606 but EFI Scan Tool shows no codes
    Paul Meister
    Paul, did you flash the ECM or the TCM...?
    Sep 2010
    Everything seems to work now with the new updates. Fired up and purrs like a kitten
    Paul Meister
    Can you explain what changed to allow it to start/run...?
    Sep 2010
    Wish I knew....I updated to the newest version and flashed the stock tune into the car and it fired up. Also had a battery charger on the car, but last night when this first happened the battery would have been fine
    No clue why scan took showed no codes but on the v2 it showed the one code.
    Paul Meister
  1. 2012 5.3 silverado knocking with stock tune
    By TravRMK in forum Gen IV V8 Specific
    Last Post: February 15th, 2012, 07:21 AM
  2. 2012 ZL1 Camaro Tune
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: February 11th, 2012, 03:33 AM
  3. Replies: 1
    Last Post: December 12th, 2010, 01:41 AM
  4. 05 CTS-V tune file
    By haulinit in forum Gen III V8 Specific
    Last Post: September 24th, 2009, 01:07 PM
  5. 07 escalade vvt w/ a 07 cts-v 6 spd tune
    By nycblazer in forum Gen IV V8 Specific
    Last Post: May 12th, 2008, 11:53 PM
