Results 1 to 10 of 18
Thread: Ab 2289 new california smog law---any affect on the tuning world ????
    Apr 2007
    Default Ab 2289 new california smog law---any affect on the tuning world ????
    AB 2289
    Set to begin January 01, 2013; Model year 2000 and newer vehicles will no longer require the tailpipe emissions test portion of the smog check process. AB 2289 will require late model vehicles be administered the smog check's visual and functional tests only.
    The implementation of AB 2289 is expected to reduce the time and cost of the smog check. The program will now take better advantage of a vehicle's OBD II technology by eliminating tailpipe testing and instead using the vehicle's own OBD II emissions monitoring system.
    This new smog test system is already in place in 22 other states. "This new and improved program will have the same result as taking 800,000 old cars off the road, also resulting in a more cost effective program for California motorists." said ARB Chairman, Mary D. Nichols.
    Currently California's smog check procedure requires all vehicles undergo a tailpipe emissions inspection to measure harmful pollutant output from the tailpipe, a visual inspection for present and properly installed emissions components, a functional test to insure the proper operation of various emission components; and as part of the functional test, an OBD II computer diagnostic check.
    Under AB 2289, the tailpipe emissions portion of the smog inspection will be eliminated for 2000 model and newer cars, trucks, vans, and SUVs.
    Background on the OBD II system - All vehicles imported into the United States as of 1996 have had to be equipped with an On Board Diagnostics system referred to as OBD II. The OBD II diagnostic system is designed to monitor all aspects of your engine's emission conditions and report this information to a central database within it's computer. This information is processed and checked against the computers pre-determined values for various input levels and performance patterns.
    If any problems are found, the computer will determine whether to alert the driver or not. If a decision has been made to alert the driver of an emissions problem, the "Check Engine" or "Engine Malfunction" light will illuminate on the vehicle's dashboard. In more serious emission conditions the computer may even begin to rapidly flash the "Check Engine/Malfunction" light indicating to the driver, that the vehicle needs immediate diagnosis/repair attention.
    AB 2289 now requires the smog test inspection to rely on data from a vehicle's own on board emissions computer to determine the vehicle's harmful emissions production as opposed to using a smog machine to sample the vehicle's emissions output from the tailpipe. This design is expected to reduce the cost of equipment at the smog station, reduce the amount of time it takes to smog check a vehicle, and reduce the cost of the smog inspection to the consumer.
    I have some concerns about this...
    for 2005+ vehicles they have an OEM supplied database of calibration ID/CVN values (CVN is like a CRC/checksum)... they will be reading the ID/CVN values from the ECM and comparing these to the database;
    for 2000-2005 vehicles I have reason to believe that they have been collecting calibration ID/CVN values from each smog test since 2009;
    so after 2013 if they detect that your calibration ID and/or CVN has changed, they will want to borrow your vehicle for closer inspection (they consider the ECM to be emissions equipment, and any tampering with emissions equipment is a felony)...
    Consider this:
    they believe in strictly enforcing the smog laws, and they will not give you anything for free, there will be a catch;
    and CA is hurting for money, and while they say they want to save the consumer money, they also want to increase state revenue (which comes from the consumer).
    Lifetime Member LB72004's Avatar
    Dec 2011
    and for diesels that don't get sniffed at the smog station? how does this affect them?
    2008 Chevrolet 3500HD DRW LTZ
    285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
    Sold - 2004 LB7 Duramax, EFI Live with DSP5 Tune
    stage 4 SC transmission, 265/70/16 tires
    Apr 2007
    JOECAR--- I agree Not quite sure how deep they will go---I'm hoping they will check only for the "readiness tests" completion and for any DTC's---But if they get into the check-sums we may have a battle on our hands-
    To me Calif is doing it absolutely BACKWARDS than i would have expected----No sniffer ?? no rollers ??? They're thinking that they will REMOVE 800,000 cars that pollute from the road---HOW????? If they wanted really to clean up the air---just stick all cars on the sniffer and if it passes---IT PASSES--period--regardless of what the DTC's or checksum or readiness tests show---That would eliminate any polluters-- So i believe their agenda is based on something else--most likely $$$$ and being in bed with the car companies to sell more new cars--- And NOT to clean up the air----Can you imagine our grief ? having to re-tune back to stock all cars we've tuned every 2 years ?? And maybe that won't even do it as i don't know if the ECM data will show that the ECM checksum reporting will show that the ECM has once been altered---Then what will we do ? replace all the ECM 's with new ones ???
    tblu92,
    Yes, it is money driven... but they are even more driven by green...
    Yes, the loaded roller exhaust sniffer test would be the simplest method of determining pass/fail.
    It also seems that they want to prevent smog shops that take "passing privilege fees" (which incurs very heavy fines if caught; there's some that are being hard to catch).
    I don't think they look at the ECM's own recorded calibration history (not all ECM's have this), but I am convinced (from what I read) that they will look at the calibration ID and CVN.
    LOL, they're removing 800,000 cars from the road every year... that's just rhetoric, otherwise a lot of people would be walking. They also claim they have prevented 3 billion tons of emissions gasses... do you have any idea how much volume 3 billion tons of gas occupies...? It's all rhetoric they use to justify their strongman control over the CA car owner (the BAR - Bureau of Automotive Repair - have more power than the CA State Police, they have the power to impound your car (via CHP) and to deny license renewal (via DMV) if they believe you're running a modified car in violation of the emissions tampering laws...)
    Sure, I am completely in favour of clean emitting cars, but there are more friendly ways of doing this.
    Aug 2007
    Question Any Updates on this
    Consider this:
    So I have a follow up question now that this has been supposedly implemented. Has anyone yet gone through one of these "new" tailpipe-less emissions checks? I've got one coming up in a few months, and I am wondering what has happened, if anything, to those of you with "tuned" ECM's.
    2001 GMC Sierra 4WD ECSB SLT, 5.3 LM7, stock 4L60E, 3.73, G80, @ 165,xxx miles
    *Installed Mods - Outlaw Intake, Magnaflow #15838 Exh., #59956 Cats, AEM Bruteforce LT's, EFI Live V2
    *Garage Floor Mods - Radix MP112 Supercharger Kit, Innovative LC-1 WB O2, FLT 4L65E LVL 7, (All gathering dust in the garage! )
    *On Order Mods/ To be ordered - T/A diff. carrier stud kit, T/A diff. cover, Circle D TB modded TC, SFI Flexplate
    Apr 2008
    is there not some tuners out there that are carb approved ( much like air filters, that you get a sticker saying that it still passes emissions)
    stock sucks
    Jun 2016
    Getting back to the original question.....
    what specifically will the Smog computers check with regards to the programming?
    I am in California.
    I am swapping an 2010 LS3 into a 2004 BMW Z4.
    so an E38 ECM.
    will Smog Check look at what ECM program I have?
    what the checksum is?
    whether it has factory programming, and DTC checks are operational.
    for a specific, something as simple as - I will have to disable VATs. so this will be a new program, and new Checksum.
    but if I touch nothing else, so all GM smog stuff has been swapped, is in place, and functioning properly, will it pass?
    or just because I have modified GMs ECM program cause it to fail?
    thanks
    Dec 2011
    what specifically will the Smog computers check with regards to the programming? - they don't check programming.
    will Smog Check look at what ECM program I have? - no. they only hook up to the OBD to check for readiness of the smog monitors, ie: oxygen sensors. and for codes
    what the checksum is? - it is a program verification done by the PCM/ECM to determine if the loaded program is legit. loosely, (i may be wrong here) it is the sum of all the bits that make up the program. this number is stored in the PCM. then if the program is altered and the new sum does not match the checksum then the PCM will refuse to run. EFI live will recalculate the checksum and update the PCM automatically so no need to worry here. also, not related to Smog
    but if I touch nothing else, so all GM smog stuff has been swapped, is in place, and functioning properly, will it pass? - Yes
    or just because I have modified GMs ECM program cause it to fail? - you will be fine. just make sure the loaded VIN in the PCM matches the vehicle VIN
    Jun 2016
    cool - thanks.
    (I know what the checksum is and does.
    I was meaning did the Smog check verify that it was the original checksum. obviously this would be a "no" per your explanation).
    a follow up:
    if I disable a bunch of stuff that sets the MIL, would that still pass?
    for example:
    P0806 - clutch position
    P0461 - Fuel level
    I won't have those, so would turn off their ability to set the MIL.
  1. New to the tuning world
    By z28_freak in forum Gen III V8 Specific
    Last Post: June 20th, 2011, 10:53 AM
  2. Unwillingly forced to join the DYI tuning world...could use help
    By Crunkmaro in forum Gen III V8 Specific
    Last Post: April 20th, 2011, 03:34 AM
  3. Tuning NB 02 lean for smog test (mot uk)
    By Gelf VXR in forum General (Petrol, Gas, Ethanol)
    Last Post: October 11th, 2009, 07:43 PM
  4. Does disabling one NBO2 affect tuning
    By hpcubed in forum General
    Last Post: July 18th, 2005, 01:58 PM
