Tried reading the factory T43 cal from a 2012 CTS-V and was given a message that no calibration found and to e-mail the file to support. I did not hear anything back from support and need to tune this car tomorrow
Paul Meister
EFI Calibrator/Managing Member, Torq Speedlab, LLC
Specializing in late model Ford, GM and Dodge EFI Calibrations
SCT, EFI Live, HP Tuners, FAST, BS3 and much much more
What is the operating system number of the tune file from the T43? Is it 24261871?
OS number 24261871 was added in the RC9 software available here:
http://forum.efilive.com/showthread....-9-Feb-09-2012
Awesome. Thanks for the help!
Paul Meister
Went to flash the PCM and the car will not start. V2 shows P0606 but EFI Scan Tool shows no codes
Paul Meister
Paul, did you flash the ECM or the TCM...?
Everything seems to work now with the new updates. Fired up and purrs like a kitten
Paul Meister
Can you explain what changed to allow it to start/run...?
Wish I knew....I updated to the newest version and flashed the stock tune into the car and it fired up. Also had a battery charger on the car, but last night when this first happened the battery would have been fine
No clue why scan took showed no codes but on the v2 it showed the one code.
Paul Meister
