Results 1 to 2 of 2
Thread: OS 15166853 DSP5 Tune Crashes ECM (Video Included) RC9's fault?
    Jan 2009
    Question OS 15166853 DSP5 Tune Crashes ECM (Video Included) RC9's fault?
    I am running RC9 and have my flashscan updated to the latest firmware and bootblock. This occurred on a 2002 LB7 while trying to install a DSP5 tune. When you first flash the truck it would start and go through the tunes just fine, however about a minute into driving the truck the ECM would freeze up. I tried recording it in the scan tool however when the truck would die it would stop communicating with the scan tool. After some time the ECM seemed to reboot itself long enough to be able to either flash or fire the truck back up, only to have it do it again. When the ecm would quit the check engine and glow plug lights would blink very fast and you could hear the relays clicking under the hood. I made the tune several times however each time was the exact same. It would take the tune just fine and start and run fine for a minute or so. I ended up flashing in a single tune which seems to work just fine. I did not get any errors on the flashscan or have any codes from the truck. I have flashed many LB7s however this was the first one after updating to RC9.
    Check out the video below
    Jan 2009
    A search probably would have helped.
    http://forum.efilive.com/showthread....-and-SES-light
    But this video might help other.
  1. Re-install of ecm/tcm-DSP5
    By BJJ-DURAMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 12th, 2010, 01:43 PM
  2. Need FBW idle training(tune included)
    By Slowrc in forum Gen III V8 Specific
    Last Post: March 28th, 2010, 10:06 PM
  3. Lean COS5 startup, tune and log included
    By smokeysbandit in forum Custom Operating Systems
    Last Post: September 20th, 2008, 03:51 AM
  4. What is causeing this knock? Video included inside.
    By Wingnut87 in forum Petrol / Gas
    Last Post: September 16th, 2006, 07:45 AM
Tags for this Thread
