Results 1 to 4 of 4
Thread: 2001 Drivder message Center
    Mar 2012
    Default 2001 Drivder message Center
    Hello,first off im new to EFI Live. Im tuning my 2001 LB7 now & was wondering if i can shut off driver message center lights such as low coolant & change engine oil. Ive looked & im not seeing anything. Thanks in advance!
    Apr 2008
    you can up the interval for oil change but not shut it right off and if low coolant light is a code then look in dtc's
    stock sucks
    Dec 2005
    You cannot shut it off, you can change you oil life to the table limit in EFI-LIVE and dummy the low coolant sensor out.
    www.mscservices.net
    Mar 2009
    Quote Originally Posted by GMC-2002-Dmax View Post
    What he said, but why? You can up the oil change interval so long as you haven't flashed your 01 ECM to an 02-04 operating system and back to an 01 operating system. As for your low coolant light, find out why it is on.
  1. Not Connected message
    By 920codyroad in forum Gen III V8 Specific
    Last Post: December 15th, 2009, 05:45 PM
  2. message center writing
    By Deereagtech in forum General (Diesel)
    Last Post: June 9th, 2008, 11:05 AM
  3. Error message
    By Chevy366 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 20th, 2007, 10:48 AM
