Results 1 to 9 of 9
Thread: WOT and ZERO Spark
    Jun 2007
    Default WOT and ZERO Spark
    Okay I have seen this only a few times and wanted to see if anybody else had also seen it also.
    The car runs normal and spark is fine but go WOT and the SPARK goes to 0 or bounces around 1-2 degrees and is dead in the water.
    Any Ideas Guys?
    Post some log files and your tune file.
    Last edited by joecar; October 1st, 2015 at 04:48 AM. Reason: I don't know how that got like that "Hi Evil"... did someone delete their post...?
    Jun 2007
    Here is the tune.
    Nothing Special at all
    Car idles, drives normal. Everything looks fine.
    Wish I had a log but did not save it.
    Go WOT and 0 if I go into the minimum table and put like 25 in it runs fine.
    Any help would be great.
    No WOT Spark.tun
    Jun 2007
    Come on Boys anybody seen this at all?
    Lifetime Member Gregs's Avatar
    Sep 2008
    I'll give it a look when I get home in about 1/2 hr
    03 Silverado 5.3 ECSB 4x4 Z71
    Comp Cam 206/212 .515/.522 112 lSA, hardened rods with LS9 springs
    2010 Tahoe VVT AFM 5.3
    Stock for now
    Sep 2008
    i don't see anything blatantly wrong, need to see a good log of the issue.
    Stock for now
    Feb 2009
    Take a look at this table, yours is set at 2000 rpm. Stock T/A is at 6600.
    {B1201} Abuse Management (in Gear) Upper RPM Threshold
    Didn't see anything else but I would start there.
    Brad
    Edit, compare your tune to a stock tune and you will see a few things to address.
    99 Firebird Formula, M6, LS6 intake, headers, catback, lid, BRE cam.
    EFI V2, V7.5.5 (Build 149)
    V8.1.2 (Build 142)
    Boot Block 2.07.01 Oct 14, 2010
    Firmware 2.07.05 Jan 29, 2011
    LC-1 with serial cable
    COS 5
    Do you get any DTC's...?
    Jul 2003
    Lol
  1. Spark at WOT goes to 0
    By Mike@Vengeance in forum Gen III V8 Specific
    Last Post: January 26th, 2012, 03:41 PM
  2. WOT, 6,000rpm, 13.5psi and 39.5* spark!!!?!?!?!?
    By tunedportcj5 in forum E37, E38 & E67 PFI ECM's
    Last Post: December 21st, 2011, 02:52 AM
  3. Replies: 1
    Last Post: July 24th, 2011, 11:53 AM
  4. Base Spark and Spark Modifiers
    By lplott in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2007, 04:33 AM
