Results 1 to 9 of 9
Thread: 2007 COS 2 Bar Turbo Truck
    Jun 2007
    Default 2007 COS 2 Bar Turbo Truck
    Guys wanted to see if anybody has the answer for this.
    2007 Silverado 408 TURBO.
    OS 12597120
    There is obviously no COS I can use on the truck OR is there. Can it be swapped out to somehting else.
    We really need to 2 bar this truck so we can get some Fuel Transisition going.
    Can I run a 2 bar sensor and cut the MAP table along with the VE in half basically making 100KPA only 50KPA. So that at 100KPA I would have 200KPA for real???
    Has anybody ever tried this?
    That is how it used to be done before any 2bar solution existed. I know out here in Australia it worked ok, well, better than as it is, but this was also on cable throttle cars, I don't know how it would go on an ETC car.
    Feb 2008
    I tuned with the modified map scaling on a turbo 8.1 running 14lbs. The resolution and mid throttle transitioning left a lot to be desired. The computer for whatever reason would only run open loop with the 2004 cos for that pcm. Hence the return to stock os and modified map. I then went to a 2005 8.1 os and went cos5 with no issues. If possible I'd suggest trying a 05-06 os and using th available cos for that earlier os. Is this an ls1 pcmb, or an e38/67?
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
    Its probably an LS1B 1MB PCM because E38s can do 2.5Bar on factory OSs.
    Good point though, I dont know what platform changes occurred between 05 and 07, but there are a few COSs for 05 trucks...
    Jun 2007
    Guys its 07 classic style truck
    Originally came with a 4.8 L
    The 0S just does not match up with anything.
    Oct 2006
    Quote Originally Posted by Evilz28nos View Post
    Tune repository has it as a ; 2007 Express Van Auto 6.0L (LQ4) LS1B 776k, http://www.tunefiledepot.com/index.p...Type=P&Stock=Y
    2006 Trailblazer
    Feb 2008
    Have you thought about reverting to a slightly older os which offers COS functions? The only thing that sucks is the copy paste functions of all the tables.
    May 2008
    bump any more info on doing this?
    Oct 2007
    Quote Originally Posted by tirefryin_s10 View Post
    i think you might have to go with a 05 gas pedal and tac module, then flash a 2005 COS
  1. COS 3.3 bar map only reading 2.5 bar
    By BAD BOB in forum FlashScan V2
    Last Post: August 8th, 2011, 12:27 PM
  2. 2007 Chev 5.3 eaton sc e38 2.5 bar tuning question
    By pandreas in forum E37, E38 & E67 PFI ECM's
    Last Post: July 31st, 2010, 05:53 PM
  3. Non Vvt Turbo Install On 2007 Lbz
    By isudiesel in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 4th, 2009, 02:44 AM
  4. Does V1 have the capability to tune a 2007 6.0 Chev truck?
    By onfire in forum General (Petrol, Gas, Ethanol)
    Last Post: August 10th, 2008, 01:49 PM
  5. Pinout for 2007 T42 (truck/avalanche)
    By Alvin in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: July 24th, 2007, 02:33 PM
