Results 1 to 5 of 5
Thread: 1994 Firebird compatibility
    Mar 2012
    Default 1994 Firebird compatibility
    Greetings all!
    I have a 1994 Firebird and would like to know if EFILive V4 will work with this vehicle. My Firebird has a V6 3.4L SFI 'S' (8th character of Vin #) engine, automatic transmission, and the ECM interface has a 12 pin ALDL plug with the serial M pin.
    If V4 is compatible with my Firebird, does anyone have a vehicle description file that will extract DTC's and real time senor data for this vehicle?
    Thank you,
    Don
    Use A257.ds for vehicle with automatic trans.
    Use A258.ds for vehicle with manual trans.
    The A258.ds has already been done for EFILive and is called GM258_L32_Fbody.xml
    Mar 2012
    Thanks Paul for your reply.
    Since I have an automatic transmission, does this mean that I can not use GM258_L32_Fbody.xml with out first modifying it based on the A257.ds file.
    Where are the ds files located?
    Is the ds file format readable with a text editor?
    Do I basically compare the two ds files and modify the existing xml file using EFILiveV4?
    Thanks again,
    Don
    I'm pretty sure the data streams are very similar.
    Take a look at this thread for more info on the *.ds files (yes they are just text files)
    http://forum.efilive.com/showthread....-buick-lesabre
    Mar 2012
    Thanks very much Paul for those files and your help. That was exactly what I needed. I've got my interface built and working now and I'm getting data from the vehicle.
    All the Best!
    Don
  1. AEM compatibility??
    By Chuck L. in forum External A/D inputs
    Last Post: July 4th, 2011, 09:50 AM
  2. Can I use V4 with a 95 formula firebird obd1?
    By 2hotbird in forum EFILive V4
    Last Post: May 18th, 2011, 12:27 PM
  3. Compatibility
    By DaddySS in forum General (Petrol, Gas, Ethanol)
    Last Post: December 18th, 2008, 12:53 PM
  4. Vehicle file for 1994 Pontiac Bonneville SSEi
    By kjhansen in forum EFILive V4
    Last Post: October 21st, 2008, 04:52 PM
  5. Viper Compatibility?
    By Donovan in forum Petrol / Gas
    Last Post: August 26th, 2008, 09:21 PM
