Results 1 to 2 of 2
Thread: "2.2 ecotec E37 stand alone No START"
    Oct 2011
    Default "2.2 ecotec E37 stand alone No START"
    Hello,
    I have a 2007 ecotec 2.2 out of a malibu which I put into a sandrail.I did a full reflash using v8 software with vats patch applied and G1210 type2. And it still wont start.
    Motor: 2007 2.2 malibu, drive by wire with gas pedal out of the same car.
    ECM: E37 which I had to order separately. When I read the tune it says its from a 2009 Ion w/2.2 OS (12630187)
    Harness: I took the harness out of the malibu with the engine as a package. I used the wiring diagrams of a 07 malibu to hook up all grounds and powers to the ecm and to all the sensors.
    When I did the full flash it wouldn't start. All of the sensors are reading correclty except for 2 senors (ECT and CMP). It reads rpm CKP but the CMP reads (0) the ECT reads (-40 degF). I checked the cam sensor with an oscilloscope and apparentley the sensor is ok, yet i still replaced it and no luck. There is no spark, no signal from the ecm gets to the coils as well as no pulse to the injectors.
    On the scanner I get the following;
    VTD-VTD1-vehicle Theft Fuel Cont-YES
    VTD-VTD2-vehicle Theft Deterrent Fuel System-Enabled
    All other VTD pids read no or disabled
    No matter how many times I full flash it or wether I put type 2,3 or theft disabled VTD pids read the same. I dont know if the computer is not compatible with the motor because of year difference. Or if it might be something that I'm diong wrong. Any type of help or guidance will be greatly appreciated!
    Thanks in advance
    Dec 2007
    crank relearn?
    -Adam Chant
    Tune it or lose it!
    2007 Saturn SKY 2.4L Automatic - E67
    EFILive Tuned
  1. "E37 Vats disable help"
    By fjs6 in forum E37, E38 & E67 PFI ECM's
    Last Post: March 11th, 2012, 12:59 PM
  2. 2.2 Ecotec e37 stand alone
    By Fixuntilbroke in forum E37, E38 & E67 PFI ECM's
    Last Post: February 22nd, 2012, 06:01 PM
  3. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  4. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  5. "PCM is in an Unkown State" & "Reflash Failed"
    By foxySS in forum General (Petrol, Gas, Ethanol)
    Last Post: September 8th, 2006, 12:53 PM
Tags for this Thread
