Results 1 to 9 of 9
Thread: Torque Converter Lockup
    Jan 2011
    Default Torque Converter Lockup
    So I've been trying to figure out the torque converter lock-up tables for a while now.. think it finally clicked and now I'm not sure if it's right because it seems somewhat simple.
    Just for an example, let's just say I set the table to keep it locked in 3rd 100% of the time. Would it lock instantly after it shifted into 3rd like it normally does when it shifts into 4th? Would it unlock during the shift from 3rd to 4th on a setting like this? Is there any setting that will force it to stay locked during shifts? I would love the locked shifts, but after a talk with my transmission builder I think I actually want to stay away from them now.
    Let's also say I set the whole table to stay locked the whole time in 3rd, would this affect anything wrong in other gears etc or does it really only kick in when it hits 3rd? I'm actually more thinking about setting it to lock quarter or halfway through third at WOT, but just want some ideas of what I'm looking at.
    '06 2500 Cummins 4x4, Billet Trans, Airdog 150, working on tuning with EFI Live!
    Member icemanjc1's Avatar
    Jun 2011
    It will lock when ever you tell it to. Problem is when you lock it up (at lower shaft speeds I'm certain) before 40~mph and reach around 40 to 42, you'll get this strange 3rd-4th locked then unlocked scenario all of the sudden (doesn't work). Won't hurt the transmission though. Try it, can't learn if you don't try.
    Joel
    -6.7 powered 2006 Ram QC 4x4 Auto, EFI Live, Garrett, Thuren.
    -08 Chevy Silverado 4x4 5.3, built 4l70E, COMP cam and Thorly headers.
    Jan 2011
    Ok I think I'll try playing with some things here soon. I've read the other transmission tuning topic so I've got a few little tips to work with.. I just didn't see much about lock-up in there.
    Sep 2011
    I am playing with this and am having problems. I changed 2nd gear a little and could notice the changes but am at stock now. I would like get 3rd to lock similar to what it is like in T/H but I can't get it to do anything. I changed the axis of the TOPS to get the needed rpms to display then I changed the graph in the tables but nothing changed in performance. Acts just like the stock.????.
    06,QC,4X4-ARE top, Bedslide ,EFILive tuned my me and Anarchy, FASS, DTT, ATS 5000 twins, PDR cam, BD IC, Carli/Thuren, Warn Air/Winch, F1 Springs, Studs
    01,QC,4X4-Banks PowerPack, RV275s,PDR35/14, FASS, Carli/Thuren/Lorenz, OnBoard Air, DTT, ARB/Warn
    Jun 2011
    Can you post a screen shot of your B4518?
    Joel
    Sep 2011
    B4518
    b4520
    Jun 2011
    I would try reducing the axis points on the unlock table as compared to the lock up. About a hundred or so, see if that works.
    Joel
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Here is the recommendation I have with these lock / unlock tables.
    First and foremost, you MUST know the output shaft speed that you you want this thing to shift at.
    Do a set of logs that are recording the trans parameters. Gov pressures, TTVA angle, TOS, engine speed and throttle position.
    Once you know exactly where you want it, it makes the adjustments a lot easier.
    1207 HP / 1612 TQ
    Sep 2011
    Rich, I used your excel file to figure the TOPS I want the tc to unlock at 0 throttle, and that is reflected in the unlock table. I changed the lock table to close the t/h table. I basically want the TTC locked above 30mph unless I'm heavy into the throttle at low rpms/speed. I haven't logged a full set of trans data yet, but I do need to. I am just dipping my toe in the water of trans tuning with something simple. I'm kinda waiting on my twins and then I'm going to get over to your shop an let you work your magic.
  1. Problems with Torque Converter Lockup
    By 2000Transam in forum Gen III V8 Specific
    Last Post: February 23rd, 2011, 04:47 PM
  2. ls1 to t700 converter lockup
    By killalux in forum Conversions / Aftermarket Parts
    Last Post: May 26th, 2010, 11:36 AM
  3. 4L80e converter lockup fix when letting off throttle?
    By chevyguy7802 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 2nd, 2009, 06:26 AM
  4. D5071 Full converter lockup?
    By DmaxHawk in forum Allison 5 & 6 Speed
    Last Post: February 21st, 2009, 04:16 PM
  5. Torque Converter?
    By Bradazz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2007, 01:28 AM
