I have an 04.5CR swapped into a Ford.
Any advice on converting it to an 06 ECM so I can run EFI Live ? I'd also really like access to the CAN bus for a few other things too.
Would an 06 ECM need a different engine harness ?
Are all the sensors the same between the two engines ? I know the injectors are different, but I assume we can overcome that with changes to the duration table ?
