Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
So then back to your original post...you'd need to install pressure gauges in all cylinders.
Hp curves, sounds, and all around engine attitude will let you know.
If your not sure...I'd suggest a private tuning session with somebody who knows how to tune appropriately.
Les Szmidt
2007 5.9 Dodge Ram
How does one know what the "Safe" pressure limit is??
Cummins won't release this info...
Les Szmidt
2007 5.9 Dodge Ram
Nope, you can see exactly when you've reached the saturation point for timing on the dyno, you just have to know what you're looking for.
You'll see it on the dyno before you hear it in the motor.
And no, the dyno is not just for WOT / Max Power.
Tunes are built based on the engines build, not one size fits all. What I have my engine timed at would blow a stock engines head gasket on the first pull.
Safe pressures are, again, based on the engines build. A stock motor vs a motor with a 12V crank, Carrillo rods, .100" taken off the top of the pistons, heavy duty rod bolts, etc., will handle different pressures.
And yes, timing values vary with RPM's.
No need for a scope, the values are right there......unless you're tuning Smarty style.
