Results 1 to 3 of 3
Thread: Tuned as a 2 bar MAP but is actually a 3 bar
    Mar 2012
    Default Tuned as a 2 bar MAP but is actually a 3 bar
    Hi all,
    I have been having troubles starting my supercharged LS1 since day dot and i think i may have worked out what the issue is.
    The car was tuned by a guru and i think the MAP sensor may have been overlooked.
    Overall i am very happy with the tune (480rwhp) but the car doesnt start without touching the throttle pedal and sometimes wont start at all if hot!
    I looked at a few things and found the MAP was reading ~40kPa without the engine running. This should be at around 101kPa as per the manual etc.
    I have a sneaky suspicion the car has had a tune with the wrong MAP scaler in it hence making it hard to start.
    I want to set it right and put the MAP scaler {C6301} to a 3 bar setting =288 but i am worried if i do it will ruin the entire tune.
    Are my fears correct? If i make a change to the scaler so that the MAP reads 101kPa without the engine running instead of ~40kPa it currently reads will it mean i will have to re-tune the entire fuel map again?
    Mark
    Feb 2008
    When you reset the MAP scaler value you'll need to rework the VE and probably the timing tables as well.
    LQ4, Pro-Flo, heads, Stock48 cam'd, twin TO4E 2001 C5 830rwhp/905rwtq
    2001 GMC RCSB pt88/5.3/4l80e/14 bolt 11.34@123.2 best pass so far with a 1,82 60' @ 13lbs boost
    By changing the MAP scaler you are now changing the indexing into the columns in the VE and OLFA tables...
    a retune is safer than mathematically shifting/expanding the columns in the VE tables.
  1. COS 3.3 bar map only reading 2.5 bar
    By BAD BOB in forum FlashScan V2
    Last Post: August 8th, 2011, 12:27 PM
  2. 2-bar MAP sensor
    By curtbriggs in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 14th, 2010, 05:52 PM
  3. 3 bar Map Sensor
    By etmotorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: October 8th, 2010, 12:52 PM
  4. 3 Bar MAP sensor doesn't work with 3 Bar scaling!
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: April 27th, 2010, 05:21 PM
  5. Custom 3 bar open loop O.S.... can I run closed for 1 bar?
    Last Post: September 7th, 2005, 09:21 PM
