7777
7777
Black06MegaCab/DTT/TDC/EFI LIVE/Gauges/Raptor150/HTTss62-71/AFEPusher/5''ss/TGC8inLongArm/Fox/38''MG ..... RED / 2005 / QCSB / G56 / SBDD / TST / Smarty TNT / ETC... K.I.A.
Alright thanks!
Aftermath Diesel Service888-494-0019Chris KlenkeCummins beta tester/EfiLive authorized reseller2007 5.3L Suburban and a 2015 Ram 2500 that's stuck on a train
I seen that one but how do you know where you want it as far a percentage before or after TDC?
06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
2001 camaro z28 ss vert with factory slp upgrades, Hooker long tubes, 3"y-pipe to a 4" muffler, ,airlid,s.s.r.a. ,t.c.bypass,descreened m.a.f. 232/234 .595,.598 +2 comp cam with ported and polished stock heads with .650 lift dual springs and a bowl grind. tuned with EFI Live. All combined to achieve 29 m.p.g. and 399 r.w.h.p. with 384 lbs of torque. sold...
Now own a 2015 1LE camaro
Keep on mind guys...as you increase timing to cool egts...your increasing piston crown temps!!!
There is a point where it's too much.
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
Ah heck! "More the merrier!" IIRC someone from somewhere that sells cheetah hair driers and tunes said running 31* or more is perfectly fine...come to think of it, what's Smarty's timing values??
06 5.9L, EFILive / Silver Bullet Tuning
06 LBZ, EFILive
Smarty's only get 25*'s of timing due to not changing the limiter. They call for a lot more, but never achieve it.
Keep in mind, timing needs to be related to RPM's. The higher the RPM's, the more you can run.
And, like Les said, more timing looks good on the EGT gauge, but thst heat is transferred from going out the exhaust to being applied to the piston crown.
Until I'm in the upper RPM's, I keep the timing pretty conservative (i.e. low single digits). Jacking up the timing in the lower RPM's isn't really needed. Keep it low to get the turbos moving and then run it up in the higher RPM ranges.
smarty calls for 32-33, but remember that pesky max timing limiter holds him to 25. I run up to 30, but that is only at 4000 rpm and higher. My tunes usually max out around 27-28 for a stockish truck.
Anarchy Diesel Tuning/ Advanced Injection Diesel Technologies
EFI Live Cummins Beta Tester
Duramax and Cummins Tuning
423-506-7427
