Results 1 to 7 of 7
Thread: Ethanol Fuel
    Lifetime Member oztracktuning's Avatar
    Nov 2005
    Default Ethanol Fuel
    I just got a tank of 10% Ethanol Fuel and did a few logs. Using a PLX wideband the AFRs which i display in AFR seem to have leaned out by about 2% . What do i do - do i tune for the same number again in AFR i.e. add more fuel in the VE table.
    Steve
    Nov 2005
    What i have done so far is add 3% across the whole map. At the moment the fuel is about a 75% mix of Boost 98 (10% ethanol) and 25% Normal Caltex Vortex 98. ....So i guess its Stoich is around 14.25 so it should be about 2.6% leaner...but once i fill again with the Ethanol Fuel this will change to 14.13 and 3.4% leaner overall.
    Oztrack
    EFILive Tuning Consultant
    Worldwide Remote Tuning Service
    2006 NSW Super Street Drag Racing Champion
    www.oztrack.com.au
    You could run one of the 2002 US O.S's with the Ethanol correction tables......get the special sensor they use......ahh, no, just drive past Shell to BP and buy Ultimate instead.
    Nov 2005
    Default Tune
    I have done the research and it is my bet that Boost 98 is better than Shell Extreme.
    The tunes dont look like they need to be that different - first run yesterday with my latest best Caltex Vortex 98 tune
    the car logged at WOT did as lean as 13.2 between 4400 and 6100 but recorded no knock retard. So it seems like a good thing.
    Lifetime Member emarkay's Avatar
    Interesting - I wonder if it would be possible to use E85 (85% ethanol, 15% gasoline) in these cars, with the proper tuning.
    Naw, never mind....
    http://www.e85fuel.com/e85101/faqs/conversion.php
    more info...
    http://www.eere.energy.gov/afdc/e85t.../e85_fuel.html
    http://www.iowacorn.org/ethanol/ethanol_5a.html
    Early EFILive V5 user - Upgraded from AutoTap for DOS!
    2000 Chevrolet Camaro Z28, A4 - For occasional day trips...
    1984 Chevrolet Caprice Classic - For the family...
    1989 Honda VTR250 - For me and me only...
    Oct 2005
    Quote Originally Posted by GMPX
    Ross, can you please elaborate on the special sensor a little more ? Is it a special 02 ? How does the OS know when you are on Ethanol vs. Petrol ?
    Senior Member Tydriver's Avatar
    Mar 2005
    Quote Originally Posted by Extinct
    FWIW, theres an active thread over here:
    http://efiforum.iqd.co.nz/showthread...hlight=ethanol
    Todd
    1993 BMW 325is <- For Sale
    2003 Silverado LS 4x4 <--- you want to autocross what?
    2005 Avalanche 5.3L LS(EFI Live tuned) <-- my gas hog running on e85 3+ years now
    2012 Subaru Outback (wife's daily)
  1. I might mix water with fuel. The ethanol manuall
    By 98 tigershark in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2009, 03:08 PM
  2. Ethanol Injection
    By 4ethanol in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 23rd, 2008, 10:09 AM
  3. 10% Ethanol
    By Chevy366 in forum Lounge
    Last Post: December 26th, 2007, 08:33 AM
  4. AFR Adjustment for 10% Ethanol
    Last Post: November 19th, 2007, 02:33 PM
  5. Ethanol
    By Chevy366 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 22nd, 2007, 12:25 PM
