Simple question
State your idle MAP pressure (PSI or kPa), and the cam setup you're using.
Maybe it'll help some of us diagnose idle tuning issues, or vaccuum leaks.
Thanks!
Simple question
Thanks!
Hi Sam,
Idle MAP goes up as cam duration and overlap increase...
stock cam idles at around 35 kPa 600 rpm.
I suppose I should list what mine is first. I am not convinced I should have this little vacuum with my cam setup, which is why I started this thread.
Cam: Texas Speed Torquer V3 Camshaft - 231/234 .643/.598 111
Idle MAP: 56-58 kPa @ 750-850 rpm
Idle MAP will be in that range (high 50's kPa) with that cam - the 111 degree lobe separation angle will reduce vacuum / increase MAP at idle. Similar cam, but with 114 degree lobe separation angle in a 6.2 L generally yields 47 - 48 kPa at 825 - 850 RPM idle speed.
Regards,
Taz
I'm at 800rpm with 42-45kPa - cam is 215/223 @111lsa in a H/C LS1.
cheers
HSV Senator 300 - the Classy C4B...
C4B - ETP215s 62cc, Comp 215/223 .601/.609 @111+3, Manley 8.050" 5/16" P/R, Morel Link-bar lifters, Powerbond 25% UDP, 36lb injectors, SLP pump, Rollmaster chain, OTRCAI, T-56 - RipShift, HydraTrak 3.91:1, DiFilippo 1.75" 4-1s, twin 3" st/st cat-back, 3" metal substrate hi-flow cats. AP-Racing 6/4-pots. EFIlive COS3 SD tune.
308rwkW(413rwhp)
Mine Idles at 950 - 1000 rpm with 75kpa cam is 251/263 .670 112lsa +3 in an LSX 454
I just got mine idling and running. I am now trying to learn how to log some data. How would I go about finding this information? My cam is a 224/230 .581/.588 on a 114. Also, is there a sticky that goes through how to scan. I have been playing with it and have a decent idea but it would be nice to read up on it a little more or have some written info I could validate I am doing it correctly before doing something stupid.
1969 Chevelle
Stock 5.3, twin PTE62/62's
E85, No intercooler
Th400, PTC Convertor, 3.90 Gears
Meth/Water Injection
Factory PCM, Wiring Harness
EFILive,V1, Daily Driver
To log data you need to go to scan, then to record data, then pick your type of ECU, that is what I do and log straight to the V2, then use the EFILive Explorer to get the information from it.
