Results 1 to 6 of 6
Thread: IAT vs Injector flow, scanners referencing ECT....what?
    Member MadMaxHSV's Avatar
    Oct 2008
    Default IAT vs Injector flow, scanners referencing ECT....what?
    Is this just bad setup on the scanner or is that what the ECU actually referencing???
    This is B1213 on the E40. The link parameter in brackets against this tables says SAE.ECT when the label says IAT. So when your logging the cursor is sitting at ECT rather than the IAT.
    Just want to check i'm not chasing my tail because of this.
    Hi MM,
    Looks like a typo in the cal_link.txt file... can you post your .tun file.
    The file C:\Program Files\EFILive\V7.5\Configuration\cal_link.txt contains this:
    Code:
    ;Injector Flow Base
    B1213.ROW=SAE.ECT
    So there's a typo.
    MM, what V7 build version are you running...?
    Oct 2008
    Thanks Joe,
    I'm on build 180.
    So I can correct the cal_link.txt file as follows?
    B1213.ROW=SAE.IAT
    Yes, you can fix it like that (and restart the tunetool afterward).
    But I alerted Paul so he can fix future builds.
    Thanks for bring it to our attention
  1. Cold start, IAT, ECT question.
    By bmax in forum Custom Operating Systems
    Last Post: March 8th, 2011, 01:21 PM
  2. Injector flow rate
    By sinr98 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2010, 04:59 AM
  3. injector flow rates
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 07:05 PM
  4. Injector Flow
    By Harrismarine in forum General (Petrol, Gas, Ethanol)
    Last Post: December 3rd, 2007, 07:24 PM
  5. Injector Flow ?
    By DWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2006, 02:50 PM
