Results 1 to 4 of 4
Thread: why cant i change my tire size
    Feb 2012
    Default why cant i change my tire size
    i have 06 with 38s on it and when i go to set my tire size it says something about how you cant set the tire size on the lly and lbz whats up with that
    Lifetime Member Mitco39's Avatar
    Jan 2009
    It interferes with the ABS, you can do it. But you will get a flashing ABS light and parking brake light in your face. EFI Live is not able to communicate with the ABS module and thus this cannot be solved with EFI Live. I have heard of some companies allowing you to flash for tires that large.
    Mar 2009
    You can chnage the speedo in a LBZ as I have done it, the problem is you can only correct for up to about a 35" tall tire. Any more than that and the ABS will throw codes as you cannot correct the ABS wheel speed sensor settings with EFILIVE.
    Feb 2007
    Change the revolutions per mile rather than trying to use the speedo calculator. Lower numbers for bigger tires.
  1. How to change tire size on LL8?
    By dirt_track_racer_81 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: October 29th, 2010, 06:55 AM
  2. Tire size change oddity and other weird issues
    By pjaneiro in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: March 6th, 2009, 10:01 AM
  3. Error Message while change tire size
    By goldbergv95 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: November 23rd, 2008, 09:37 AM
  4. LBZ tire size change
    By BigTex in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 12th, 2007, 03:14 AM
  5. Tire size change calulation
    By Z16DNA in forum General (Petrol, Gas, Ethanol)
    Last Post: January 19th, 2005, 08:52 AM
