Page 1 of 25 12311 ... LastLast
Results 1 to 10 of 257
Thread: Deleted 6.7 throws "See dealer for service" message on overhead display.
    Jun 2011
    Default Deleted 6.7 throws "See dealer for service" message on overhead display.
    I have a fully deleted 6.7 that throws a "see dealer for service" message on overhead display and makes a ding ding ding sound to alert me. Is there a way around this?
    Apr 2006
    Have you tuned it? Max out 6283-6286
    Jun 2011
    Yes. I'll try that. I totally removed the DPF module and all related wiring.
    Jan 2012
    I have the same problem, and I have tried them maxed out and stock, also minimized and still the same. If I do a reset, it will go about 40 miles before it dings off again and then every 10 miles from there out.
    07.5 Mega stock
    00' EX-Cab MFI
    Jun 2011
    I have also changed/disabled F1031,F1190-F1196,F1204&F1229
    There is no performance issue, it's purely unamusing.
    Jan 2012
    I also have had no issues with performance or limping the truck, just annoying as all getup on a road trip
    07.5 Mega stock
    00' EX-Cab MFI
    Jun 2011
    OS 11620807 in a 2008 truck has this issue.
    OS 11551035 in a 2007.5 truck does not.
    I guess I'll try an OS swap and see what happens.
    How do you clear it. When Ross and I were working on trying to get the OH to quit acting up (maybe mid feb), we gave up on it for a while and since then mine went into full filter status and now I can't clear codes to get rid of it. I don't even know if my new tuning has solved the issue or not. But it seems to be. I'm running the same OS as a couple of local trucks that we have had tuned for over 2 weeks. None of them have the issue. So I'm thinking that its fixed but haven't had time to figure out how to get the oh to go away. It says limp mode (or power reduced, whatever) But its not in limp mode and I don't have any dtc's... I guess when rc10 came out that's when we got it figured out, but I havn't had time to jack with my personal..
    One of our beta testers came across this too, he said....
    "ended up plugging off both of the pressure tubes that went to the DPF. As soon as he did this the message went away and has not come back."
    Might be worth a shot.
    Jun 2011
    The truck that has problems has a total delete. Wiring harness and dpf module removed, pressure sensor removed, dpf gone, egr gone and intake throttle valve gone. The other truck without issues is identical.
  1. DIC reads "clean exhaust filter" DPF DELETED
    By ptownbacker5 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 28th, 2008, 05:10 PM
  2. "Service Airbag" message :(
    By scdyne in forum Petrol / Gas
    Last Post: May 4th, 2008, 01:08 PM
  3. Replies: 3
    Last Post: July 20th, 2006, 10:19 AM
  4. "Service Brake System" message after tune change
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: September 11th, 2005, 02:26 AM
  5. Make a "LED" display on a dashboard gauge
    By emarkay in forum Tips and tricks
    Last Post: September 4th, 2003, 07:50 AM
