Results 1 to 10 of 13
Thread: Injector Flow rates?
    Mar 2012
    Default Injector Flow rates?
    Will/can EFI live adjust injector flow rates and why would I want to if it can?
    Mar 2012
    No answer? Guess I won't be buying efi live if I can't get support in thier own forum.
    Relax man, I saw your post last night, but I have very limited experience with Duramax stuff. Having a post where someone says "I dont know" isnt really helpful IMO.
    Have you downloaded the software and played with it? You can open and EFILive tune file without owning the hardware, it will tell you exactly what tables are available for your truck. What truck do you have, makes a difference because different ECMs use different tables.
    Feb 2007
    There is no "Injector Flow Rate" table, at least not like what is in a gasser. What are you trying to accomplish?
    Mar 2012
    I am trying to gain clarification on this subject.
    I have a newly purchased 2008 Chevy 2500 with the Duramax LMM motor. It has 170K, and needs a set of injectors. THis is my previous company truck I just purchased and I have had 5 injectors swapped out at various times over the last 3 years. I want to replace all 8 injectors at one time (Suggestion from Dealer and local mechanic), and when you change the injector you have to update the injector flow rates in the ECM. I am trying to find out if EFI-Live is capable of this, or if I need to purchase a 3K Tech-2 programmer from a dealer. I am not concerned about "tuning" as much as I am about repairability of my own vehicle.
    Feb 2007
    You do not "have to" program the injector codes, but to answer your question, last I checked, you could not do it with EFILive for new injectors. You can program from the GPCM to ECM and vice-versa, but you can't do anything for new injectors.
    Junior Member the_red_shark's Avatar
    May 2008
    I'm not familiar with diesels but if you are replacing injectors unless you are increasing or decreasing the size injector flow rate would not require changing.
    May 2009
    Quote Originally Posted by the_red_shark View Post
    Actually on at least 07.5 and newer dodge and duramax engines the injectors are calibrated to the ECM as far as flow rate, and if the injectors are replaced the new flow rates have to be programmed into the ECM for emissions or a code will set. They are programmed based on i believe injector serial number. This way over time the ECM compensates for expected wear in the injectors to keep fuel delivery close to desired values. It's not exact, but a heck of a lot closer than no compensation at all.
    Jun 2011
    Quote Originally Posted by cumminsDK View Post
    My Snap-on Modis will allow me to change injector codes on the 6.7 cummins however I never had it on an LMM to see if it's an option because the EFILive scan tool is far superior. Unless the replacement injectors are new genuine Bosch parts, the balance numbers are meaningless.
    Member Motorzane's Avatar
    Jun 2011
    The Snap-On software will program the ECM and the GPCM on the LMM
  1. E35 injector flow rates
    By vectorbundle in forum FlashScan V2
    Last Post: February 20th, 2011, 10:41 AM
  2. injector flow rates
    By GMMAD in forum Gen III V8 Specific
    Last Post: January 21st, 2011, 07:53 PM
  3. Injector Flow Rates
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 22nd, 2010, 07:22 AM
  4. injector flow rates
    By 02sierra4x4 in forum Gen III V8 Specific
    Last Post: September 30th, 2009, 07:05 PM
  5. 44lb injector Flow rates?
    By lownslo in forum Gen III V8 Specific
    Last Post: April 14th, 2009, 02:01 AM
