You didn't happen to forget to plug the MAF back in did you?
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
Got me scratchin... don't see any reason why either one of them won't run unless you had the MAF unplugged with the AutoMAF tune - that definitly wouldn't run LOL...
GM EFI Tuner
not log attached....
GM EFI Tuner
here is logs, did i do my map right?
can't see your map - those are created locally (I have to make my own), but you have the correct data logged... do a screenshot of your map and load it up so I can be sure you did it right... I'll correct the MAF and reload it so you can see what I would do...
GM EFI Tuner
heres the maps
Here you go... on the next run, push it up further in the MAF frequency - watch the correction and make sure it doesn't go too lean... should be pretty smooth at this point. Lookin good!
GM EFI Tuner
now after this i hit average, apply filter, and copy and paste with labels into my tune file just like autove right
No, the map isn't right - you need to put the BEN factor in the data tab... see Joe's explanations above if you need to... should look like this... with filter applied...
GM EFI Tuner
