ok thanks ill try that
i also found the gm asa data. it does differ a bit from the txt that i listed here. so might try that in a little bit.
never mind i found where i messed up one table .its fixed now per asa and runs !!
in b4001 if you look at the bosch.txt file i think its in different units. then if you look at my tune file i fixed it per the asa figures. my mistake.
so my b4001 now reads
LABELS Injector Flow Rate (Grams/Second)
Manifold Vacuum kPa {link: GM.MANVAC} Value
0 5.054688
5 5.085938
10 5.117188
15 5.148438
20 5.179688
25 5.210938
30 5.242188
35 5.273438
40 5.296875
45 5.328125
50 5.359375
55 5.390625
60 5.421875
65 5.445313
70 5.476563
75 5.507813
80 5.539063
and i misunderstood the b4001 bosch.txt file that says
[B4001]
;Row Data
0= "40.117135"
1= "40.365155"
2= "40.613174"
3= "40.861194"
4= "41.109213"
5= "41.357232"
6= "41.605252"
7= "41.853271"
8= "42.039286"
9= "42.287305"
10= "42.535324"
11= "42.783344"
12= "43.031363"
13= "43.217378"
14= "43.465397"
15= "43.713416"
16= "43.961436"
Yep, 40 g/s vs 40 lb/hr is a big difference, glad you found it.
ok guys so i have the injectors set for now.. and here is my autove tune and my first log, just so you can check it out. now from here on out i apply the filter as stated in tutorial and follow the tutorial for now correct. thank you for the help so far. im still learning that spread sheet even though i found the table data b/c in future i may wanna change or help a friend.
also this is my ben map avgerage before any filters applied. also this is from some short neighborhood driving, freeway, and some small 1-4 pulls
Whoa - B3605 is way jacked up! You are commanding way lean... Let me look over your tune and I'll post up some suggested changes.
GM EFI Tuner
02 WS6 9.41 @ 143 MPH 3675#, drag radials, pump gas, through the mufflers - sold
CRap I don't know why I did that again. I'll fix it. I messed that up first time
Here, try this one...
GM EFI Tuner
