Results 1 to 10 of 13
Thread: DBW Throttle response
    Jan 2012
    Default DBW Throttle response
    Hi All,
    I am wondering if people are having problems getting their DBW throttle to respond quick enough, mine just seems sluggish when closing, just seems to hang the throttle for a split second between gear changes, just something that is a little annoying really, pretty sure it has always been this way. It is a Nick Williams 102mm on a Fast 102mm Intake attached to my LSX454, has quite a large cam in in, and manifold vacuum is apparently a little bit of an issue too.
    Any help would be appreciative to try and get it to activate quicker all round.
    Jan 2012
    Does anyone have a tune file I could look at to see what differences between my settings and theirs is? I have heard mixed stories that in Australia we have issues, but in the states there doesn't seem to be one, there are different tables or something, just something I am wanting to look into and see if there is something that could be changed and help people in Australia deal with this issue,
    Has anyone else heard of any issue with the 102mm TB here in Australia?
    Jul 2007
    I've heard that some NW TB's can stick, but I think it may just be the tube settings. Of course, letting us know what sort of controller you are working on would probably help...... It's probably easier to post the current tune than have random stuff posted back.
    Simon.
    We've installed quite a few LSX 454 engines...if you are using the factory camshaft it's got poor VE below 2500. Dont expect and great throttle feel. You shoud try feeding it some decent spark down there even at low rpm low load areas..
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Jan 2012
    Quote Originally Posted by swingtan View Post
    Simon.
    Hi Swingtan,
    It is Jezza's tune, I am just seeing if I can get the throttle to respnd better, have it open and close quicker, have heard of a few problems with them not working properly. Mate of mine had the issue and he removed his and went back to the stock one. I can email it to you if you like, I don't know how Jezza would feel if I put it up on the forum.
    Quote Originally Posted by Redline Motorsports View Post
    Howard
    I went for a custom cam, but it is also having low manifold vacuum at low rpm as it has a 112LSA. A bit bigger then the stock one too, 251/263 .670 112LSA+3
    I will have a look at what the spark is like, I am not really all over the tuning yet, trying to learn but it is a slow process with everything else happening.
    Jun 2012
    wow big cam i have a 242/254 .623/.623 112
    Lifetime Member Chuck CoW's Avatar
    Feb 2006
    Hey Howard! Someone you know sells something called "CoW BOOSTER!" that makes all those problems go away!!!
    Chuck CoW
    CoW BOOSTER! Electronic Throttle Enhancement.
    - CLICK HERE NOW FOR MORE INFORMATION! -
    VARARAM, EDELBROCK, AMERICAN RACING HEADERS, BAER BRAKES, BORLA, EFI Live, Magnuson,
    COMP Cams, PROCHARGER, PRO TORQUE, PHADT Racing, INNOVATORS WEST, and more.
    Aug 2004
    Try Messing with the Throttle Follower tables for it to come down faster, The TPS response on decel is changed by that. Throttle cracker as well. Throttle follower effects the rate at which the airflow is back to 0 adder.
    Aug 2004
    Also, if you are using a newer ecm, like e38, the direct airflow tables can be tweaked to allow it to come down almost instantly. The throttle body opening needs to be adjusted in the software as well, that will also increase the responsiveness.
    Lifetime Member Boost's Avatar
    Dec 2006
    Quote Originally Posted by wait4me View Post
    Would this apply to say an '08 4.8 Silvy that the customer says 'revs down' too slow in P/N?
    8.7 @ 84 (1/8 mile) bolt-ons
  1. DBW is closing the Blade under hard throttle, HELP!!!
    By JS1965 in forum Gen IV V8 Specific
    Last Post: November 20th, 2012, 03:15 AM
  2. Help! Only getting 25% throttle with my DBW Pedal.
    By Laychut in forum Gen III V8 Specific
    Last Post: February 26th, 2012, 01:56 AM
  3. Throttle response
    By catman3126 in forum Duramax LLY
    Last Post: July 11th, 2011, 03:27 PM
  4. LH6 to LS2 DBW no throttle operation
    By ssvolvo in forum Gen IV V8 Specific
    Last Post: March 23rd, 2008, 10:47 PM
  5. Better Throttle Response
    By dirt_track_racer_81 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 8th, 2006, 03:43 PM
