Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: E40 2 bar Dyn Air dropping and so is fueling and everything else
  1. #11
    Sorry, I don't know, maybe try what I'd suggested with the tables.
  2. #12
    Jul 2003
    That is what I have been doing thus far... :(
  3. #13
    Jul 2003
    The tuning way I am using is SD but with 1-bar type tuning :facepalm:
    There has to be an issue with the code and the ECU or something.
    I did another E40 custom OS and I didn't have an issue (GTO 2006). Go figure.
  4. #14
    I know Chris, this is the same problem that has happened out here on occasion, in fact I think it was even the same OS on different cars, one was fine, the other was not, definitely a weird problem when it pops up.
  5. #15
    Jul 2003
    I tried flashing different OS's. ALl did the same thing... I did use a script to adapt the calibrations for easy access... it has got to be something in the calibration.
  6. #16
    Lifetime Member JezzaB's Avatar
    Nov 2006
    I had this problem a while ago. If I flashed it again it would be fine etc. Then another flash later and it would go back to the low reading dyn_cyl air again.
    This was around the time of a new update that broke the Boost VE table and it wasnt reading correctly so I havent had a chance to look at it again but will be in a couple of weeks.
  7. #17
    Nov 2006
    Had this happen again yesterday. It's bloody weird. Full flash and it's fixed again.
  8. #18
    Nov 2006
    Spent more time today. Every few flashes it would do it. Makes no sense at all. Just have to keep reflashing until it comes good.
    I had 2 in a row bad and the third time (same tune and literally key off and reflash) was fine. I can tell straight away because it idles lean
  9. #19
    Jul 2003
    It should be nice to develop a way to know when it works and when it doesn't. And, if it will stay like that or will it reset? This could mean a blown engine!!!!!
  10. #20
    Nov 2006
    Ive had a run of E40s lately. They are fine 1 bar stock OS but going to 2 bar things become very iffy. G/cyl drops, goes lean randomly etc. Theres something not right. Couple of years ago it was fine, you would upgrade to a 2 bar OS and use the Boost VE table fine. Driving me insane as I have to keep trying tunes and OS until it works.
  1. E40 dynamic air/ MAF issues w/ cam install
    By HTMtrSprt in forum Gen IV V8 Specific
    Last Post: December 3rd, 2010, 11:28 AM
  2. Reduced Power at Half Throttle 5psi Boost - Turbo LS2 E40 Trailblazer SS 2 bar MAP
    By GMBlair in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: November 1st, 2010, 08:27 PM
  3. 2 BAR COS on E40 LS2
    By MadMaxHSV in forum Custom Operating Systems
    Last Post: July 21st, 2010, 08:53 AM
  4. LS2 E40 2 Bar Custom OS
    By vetteboy2k in forum Custom Operating Systems
    Last Post: November 28th, 2007, 02:27 PM
  5. What are the differences between the DYN air pids
    By Dirk Diggler in forum General
    Last Post: March 30th, 2005, 09:16 AM
