Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Converter unlocking at 80 mph
    Oct 2011
    Default Converter unlocking at 80 mph
    Went for a nice long drive this weekend and discovered my converter unlocks alway around 76-80 mph just cruising. The lockup and release for tps is set right but it still unlocks. It will also relocks at 70 after a couple mins. Is there anything else that could be making it unlock?
    2018 Colorado ZR2 Diesel
    1998 Firebird Transam A4
    Installed: 4l80e with yank 3200 stall, mwc 9in 3.00 gear wavetrac 3in off the sides, wattslink, PCM upgrade, Strano springs, 24 way QA1 front/rear, stainless steel brake hard lines, pst carbon fiber driveshaft, Boyd Harm rims 18x12/18x10(not minitub), kooks 1 7/8 full lenght headers and true dual exhaust, Zainoed
    Log the misfire count pids, and brake switch state (it's in one or more of the TSTATExx pids).
    Oct 2011
    Ok going to try and log it today. I know tstate12 was blinking yes/no at idle thought that was weird
    Oct 2011
    well ran a log its unlocking cause of misfires very strange doesnt feel at all like its misfiring.
    tst.efi
    Guess my next question is why is it misfiring. put brand new o2 sensors in.
    I see the LTFT's pegging high, indicating a lean condition (over the entire log), the HO2Sx1 voltages support this;
    so either a lean condition exists which causes misfires (but I see only 11 seconds worth of misfires),
    or misfires occur which causes the O2's to report lean (O2's see unburnt oxygen);
    Is this a newly installed stall converter...? Did anything change on the crank (e.g. converter, flexplate, pulley)...? If so, did you do a CASE relearn...?
    If this started happening without any parts/tuning mods, then check for:
    - airleaks (MAF, intake, injectors, exhaust, O2's, cats, PCV, AIR, EGR),
    - check ignition components,
    - internal coolant leaks;
    If this started happening after tuning changes, then check that the VE and MAF are not under-reporting air.
    Only 11 seconds of misfire occurs (what triggered it...?), but LTFT's are pegged positive for the whole log (why...?).
    BTW:
    your log shows 31 pid channels (shown at bottom of PIDs tab)...
    if you can reduce the pid channel count to no more than 24,
    then the sample rate will be highest (10 Samples/second vs 5 S/s)...
    for future misfire logging, you can remove these pids:
    - TRQENG (2 channels),
    - EST_BASE_DMA (2 channels),
    - STFT1/2 (together 2 channels),
    - TFT (1 channel);
    [ you now have 24 pid channels ]
    Oct 2011
    Well I've noticed misfires since I change the PCM. Ever since then when I load a program it always wants to add fuel. then it evens out and is fine. I'm been also getting heat performance on bank 2 sensor 2.
    With the new PCM and when I put in the new converter I did a case relearn.
    Don't know if this would do it or not but when I installed the PCM I had a couple evap codes that I ended up setting to not report. It could be that I don't have it plugged in. Would that have anything to do with this?
    Oct 2011
    I had 4 extra wires leftover from the repin
    If you have EVAP, AIR, EGR emissions systems, check that each one is not leaking...
    The EVAP system might be allowing an airleak, I would have to read the description of it again.
    Oct 2011
    If it help I believe it was setting p0443 dtc before I turned it off
    Oct 2011
    Hmm now checking my repin those are the first 2 pins to change so I must have another issue going on for evap.
  1. Unlocking pcm
    By carter01 in forum Gen III V8 Specific
    Last Post: May 23rd, 2011, 12:36 PM
  2. unlocking a locked PCM
    By rubbersidedown in forum Gen III V8 Specific
    Last Post: August 12th, 2010, 11:47 AM
  3. Unlocking PCM
    By mjp80538 in forum General (Petrol, Gas, Ethanol)
    Last Post: December 16th, 2006, 02:56 PM
  4. Pcm Unlocking
    By JCA in forum Tips and tricks
    Last Post: October 19th, 2006, 03:22 AM
  5. Locking and unlocking converter in 3rd gear
    By Scott(382-$T$) in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 29th, 2006, 04:25 PM
