Results 1 to 10 of 14
Thread: HELP! ECM Crash
    Dec 2005
    Default HELP! ECM Crash
    I will post here instead of DP where last post was. I was doing a partial flash, and when the upload said complete, I let truck sit with key off for about 30 seconds. When I turned the key back on, the check engine light was flashing very fast. No crank, no start. Flashscan says cannot communicate with ECM. Removed battery cables for about 10 minutes and retried flash. No luck. Would it be possible to recover frim this tragedy? Would I have to do a full reflash? Is it possible to do a full reflash of ECM in these circumstances?
    04.5 2500HD LLY EC/LB
    14 Sonic RS Sedan
    GM Certified Technician
    President of the 'I killed an ECM' club
    Well, I don't know what could have gone wrong on a partial flash to put it in this state, very odd indeed.
    When you try to reflash now what is the exact error you get?
    Cannot communicate with ECM or cannot communicate with Flashscan or the ECM takes the flash but you are still in a no start situation?.
    If you want to Email direct, send to ross at efilive dot com
    Dec 2005
    Cannot communicate with ECM is what is said. Was able to get ECM in in state of repair once, but did not take flash and will not communicate at this time. Still listed on FlashScan tool, but not responding to read or write commands. Thanks for your help.
    14 Sonic RS Sedan
    Mm, O.K, can you please Email me (if you don't mind), the file that you last flashed in to the ECM. I'll flash it into an ECM here to make sure the file itself is O.K. Oh, also, does it communicate with the Scantool?
    Email address is in my first post.
    Dec 2005
    File sent. Hope you can find the problem for me. Thanks
    14 Sonic RS Sedan
    Lifetime Member bobo's Avatar
    Nov 2005
    Is it fixed?
    2005 Twin Turbo Dmax/Allison Ext. Cab Short Box 4X4
    Best 1/4 11.8 @ 118+ on #2 only
    Twisted Diesel Tuning-The leader in Duramax Tuning Services and soon to offer Common Rail Cummins Tuning!
    Bobotune at rocketmail dot com
    Lifetime Member Max Power's Avatar
    Nov 2005
    Did you try disconnecting the batteries for a few minutes then plugging back in and seeing if you can communicate. I was under the impression that there is no way to kill an ECM by doing the part reflash.
    09 LMM Duramax
    Dec 2005
    I have found a way to kill the ECM with partial flash. Also killed one of Ross's test ECM's with that configuration from what he said last night. Do not set speedo pulses to 0! Appears to send them into neverland. Not recoverable with any programmer unless EEPROM is pulled and reconfigured.
    14 Sonic RS Sedan
    Senior Member Wasted Income's Avatar
    Dec 2005
    Holy crap!!!
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Dec 2005
    The customer service from them has been great. Have it all covered. Hopefully this does not happen to anyone else.
    14 Sonic RS Sedan
  1. EFILive V4 crash
    By kjhansen in forum EFILive V4
    Last Post: December 19th, 2012, 05:36 PM
  2. LS1 Controller EEPROM Reflash after crash
    By SBTuner in forum Gen III V8 Specific
    Last Post: October 19th, 2007, 02:01 PM
  3. Computer Crash = Lost Factory Tune!!!
    By RacerChris in forum Gen III V8 Specific
    Last Post: March 30th, 2007, 10:46 AM
