Results 1 to 6 of 6
Thread: Will a new e38 eliminate my scaling headache?
    Mar 2012
    Default Will a new e38 eliminate my scaling headache?
    I know the 2010 and up maybe 09 too have the higher injector IFR I need for my 85# injectors, so if I bought one that will eliminate all scaling issues for SD? Are any of the new OS compatible with an 08 pcm for a full flash? Is there a e38 comprehensive scalling tutorial I cant find? I think I've pieced together how to do it but not a %100 sure.
    Aug 2010
    Flashing a 2010 E38 calibration into a 2008 E38 ECM - will terminate (brick) the ECM.
    Regards,
    Taz
    Sep 2011
    I too would like to know any ideas for scaling large injectors, I am taking the 'half the base injector flow B4001' and double the stoich approach at the moment on a 2006 vette, I'll see if it works.
    Greg covers how to deal with the limited injector flows in the early E38's in he's tuning DVD.
    http://www.summitracing.com/parts/SME-DVD-2/
    Jul 2004
    Or weirdly enough, you can get it here also: http://www.fishtuning.com/LearnEFILive
    Ira
    Mar 2012
    Thanks for the replies, but I just picked up an 09 e38 from an Impala for $50 that has the bigger IFR and MAF limits.
  1. Why reduce MAF scaling values on a basically stock E38?
    Last Post: June 24th, 2011, 11:44 AM
  2. lc-1 hookup headache
    By Gregs in forum Petrol / Gas
    Last Post: May 29th, 2010, 05:43 AM
  3. lower/eliminate TC functions.
    By acomp917 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: February 23rd, 2010, 09:28 AM
  4. eliminate EVAP system...
    By WiseGuyZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2007, 12:36 PM
  5. Eliminate TCM
    By thetallengineer in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 29th, 2007, 01:27 AM
