Results 1 to 10 of 18
Thread: Cylinder Balance Help ASAP Please
    Junior Member TwoStroke's Avatar
    Jun 2011
    Default Cylinder Balance Help ASAP Please
    Are the cylinder #s by the firing order or the actual cyl as labeled? Such as is BALRCYL2mm3 actually #5 inj?
    Nov 2010
    They are listed in numerical order from front of motor to the firewall.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Jun 2011
    That was my thinking also until this morning. I had a truck come in that logged #2 injector at +4.0 and would never change. I pulled #2 cyl injector and replaced, logged and no different still +4.0 with no fluctuation. So I recall on the modis or mentor that it list the injectors in order from firewall but also in parenthesis has them listed in firing order which would put #5 cyl as Balrcyl2mm3 . I pulled cyl #5 inj and replaced it leaving #2 new alone for the time and logged it. Problem solved.
    Hope I explained it well enough to understand.
    Nov 2010
    Interesting...
    Les Szmidt
    2007 5.9 Dodge Ram
    Apr 2008
    there is no good scanner to do this at the shop i use to work at we use to pull the injector wires to find out what injector it is
    #2 and #5 are running mates in the firing order
    stock sucks
    Senior Member DODGE74's Avatar
    Oct 2011
    Ok, I want to hit on this some more...
    Im having an injector issue and just out of curiosity I would like to see if I can nail down which injector is causing the problem. Im getting ready to buy 6 new 120's and I just figured I would try and do a little investigating before I pull them and send them to the injection shop for testing. So I set up my dash page with the injector balance rates and Im wondering why I have cylinder balance rates for 1-5 but no 6?
    What would be considered normal for the balance rates? I have one injector that is showing 4.0 at idle and the rest are fairly close to each other but Im also not showing #6.
    Here are the rates that Im showing at idle:
    cyl 1.... -1.1
    cyl 2... -2.6
    cyl 3... 4.0
    cyl 4... .03
    cyl 5... -3.9
    If I can figure out how to post my log file I will or maybe someone can show me how to do it I would be appreciative.
    06 QCLB, DRW
    Single pump
    Single turbo
    EFILive 772hp 1398tq
    gordon@innovativediesel.com
    Jun 2011
    The closer to 0.0 the better. A +4.0 is telling you that the ecm its really working that injector to try to get it to balance out the engine. On the other hand a -4.0 would mean the ecm is trying to cut that injector to balance out the engine.
    Sent from my DROID RAZR using Tapatalk
    Nov 2010
    Your +4.0 hole is the dead injector...the ECM is calling on the others to help balance idle quality.
    Les Szmidt
    2007 5.9 Dodge Ram
    Oct 2011
    Thanks guys. I kinda figured as much but its nice to get some knowledge from the experts.
    But why is there no #6?
    On a side note, I just dynoed the truck and I've been loosing hp gradually and that was my first suspicion something was going on. Here in the last week or so its been fairly warm here and I'm geting some white/blue smoke at startup with about 5 seconds worth of rough idle. So I know whats gotta happen next.
    But it did put down almost 550hp and 1066 like this.
    06 QCLB, DRW
    Single pump
    Single turbo
    Jan 2011
    So at about + and - 4.0 means the injector is starting to go out? Is this at idle or what type of driving? I think mine might be starting to go, but of course still hoping not... Don't mean to derail this thread, but I've been looking for this info.
    '06 2500 Cummins 4x4, Billet Trans, Airdog 150, working on tuning with EFI Live!
  1. Can't do cylinder balance test. Help
    By tichey327 in forum Diesel
    Last Post: October 24th, 2011, 08:30 AM
  2. Cylinder balance test?
    By DrX in forum General
    Last Post: April 22nd, 2006, 01:40 PM
  3. Cylinder Balance Test
    By driver456 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 17th, 2006, 12:49 PM
  4. Cylinder Balance Test
    Last Post: October 11th, 2005, 04:17 PM
  5. Cylinder balance test - how to interpret it?
    By 2000ssnb in forum Tips and tricks
    Last Post: November 24th, 2003, 09:34 AM
