Thread: Injector balance rates what # makes you worry?
    Aug 2012
    Default Injector balance rates what # makes you worry?
    Hey fellas got around to checking out my injector balance rates at idle. I have 4 good ones, then #3 averages +3.2 and #5 averages -2.0.
    What # do you start becoming concerned? I think I read +-4 and it's time to go shopping but IDK.
    Truck had 49K and since 36k has had 3 micron filtration. Thanks, Rye.
    06- TRE/E.D./EFI by Les@SilverBullet
    Senior Member DODGE74's Avatar
    Oct 2011
    Hey Ryan,
    check out this thread. It might answer a few questions for you.
    http://forum.efilive.com/showthread....lp-ASAP-Please
    06 QCLB, DRW
    Single pump
    Single turbo
    EFILive 772hp 1398tq
    gordon@innovativediesel.com
    Aug 2012
    Thanks Gordon, got to say maybe because I'm a Former Marine, I'm still a little confused as to what number EFI shows vs what number it is in the truck. As it seems it may be in the firing order or it may be from front to firewall. I also did my log at cold start up, I'm gonna try it again at operating temp just to compare. Still don't know if the 3.3 is worth panicking over, no smoke at start up, no poor idle quality, and no miss. IDK.
    Nov 2010
    In my mind and the way I work...anything over 2.0 is showing signs of a weak nozzle...over 3.0 and its time to look for new nozzles. Over 4.0 and your on short time and by then your gonna have some performance issues.
    Same thing goes for the (-) numbers...anything over a -3.0 and your running into smoke issues and probably a mm3 value that has wild swings in it at idle.
    Anything either side of 0 +/- 2.0 and I say its good. Above and over that...its time for some injector love.
    Of course this is my opinions and how I work..other may feel/say differently.
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Oct 2011
    Quote Originally Posted by RyeThomas View Post
    If your not having any issues then I wouldnt let it bother you.
    Plus, if your in tune with your truck like I am with mine then you'll know when somethings not right.
    I was having a rough idle for about 3-5 seconds with white smoke.
    It was time for me.
    06 QCLB, DRW
    Single pump
    Single turbo
    Aug 2012
    Thanks guys for the answer, I will keep an eye on it and log it a few more times and see. Got my new tune with some added fuel toady time to go for a ride!
  1. LB7 injector balance rates
    By minytrker in forum Duramax LB7
    Last Post: August 24th, 2014, 02:51 PM
  2. injector balance rates
    By Hunter t in forum Diesel
    Last Post: June 11th, 2012, 12:38 PM
  3. How to scan/check injector balance rates?
    By duramax07tmd in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 7th, 2011, 02:50 PM
  4. LB7 Fuel Injector balance rates reading 0
    By StuntHeavy in forum Duramax LB7
    Last Post: July 7th, 2010, 02:03 PM
  5. Balance rates
    By diesel freak 123 in forum Duramax LB7
    Last Post: April 22nd, 2008, 02:55 PM
