After quite a bit of tuning and logging I'm a little lost here. I'm comparing my tune file to my log file and for some reason my highlighted sectors in my tune file (main duration table) don't match the scan file. If I run them side by side my tune shows a larger duration that it's calling for, but the logs show it's not producing near that in the real time situation. The only time it doesn't do this is around shift points. It shifts into second at 15mph~, 3rd @ 26~, OD varies but does the same. Quite honestly, I've been starring at this scenario for months, along with wondering why my truck has a nice jolt in power right after a gear change then... sag.... I've attached files of both.
Garrett 5 0001.efi
Garrett 5.ctz
