Results 1 to 5 of 5
Thread: Updates and such...
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Question Updates and such...
    Hey guys,
    I have loaded and functioning as designed V7.5.7 build 180 and V8.2.1.Build 170
    ON the site you have V7.5.7 build 201 and V8.2.1 build 191, no problem, it looks like an update is possible or needed.
    When I click on Start, EFILive, V7.5, Tools, Check for new Update
    I get a nice popup box that says it is checking for new updates. It thinks for a bit and then very nicely says, Nope, there are no updates.
    Um, why did it say no? Did I screw up something again?
    Elmer
    No you didn't screw up. The 180/170 release is not "upgradable" to the 201/191 release.
    You need to download the latest software manually and install it manually. Once you have the 201/191 release installed, you can then use the "check for updates" for future updates.
    In the new versions, the check for updates is on the Help menu in the V7.5 software and on the main screen of the v8 software. You need to update V7 and V8 independently.
    Apr 2004
    Thanks Paul. I'll be getting to the updating now.
    Elmer
    Apr 2004
    Painless as can be. All Done.
    Elmer
    Elmer, ok cool from now on it will be painless.
  1. Updates and changes
    By eboggs_jkvl in forum FlashScan V2
    Last Post: October 15th, 2008, 10:48 PM
  2. Any new updates for 7.5.1 yet?
    By BowlingSS in forum General (Petrol, Gas, Ethanol)
    Last Post: January 9th, 2008, 05:27 PM
