Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: ECM Failure
    Aug 2004
    I have some of EVERY computer in stock.. After you get a quote from another company, Call me and i will tell you my price..
    Oct 2003
    On this particular vehicle, the sending unit shipping pulses to the PCM is quite a bit different than the std. F-body stuff the PCM expected. I calculated it needed roughly 1500 ppm to make the speedo read correctly, so I entered 1500 ppm. Flashed the PCM, and it turned into a doorstop :(
    Quote Originally Posted by Brains
    I do not think that 1500 will kill the PCM. We have tested it as low as 100ppm and it was ok. 0ppm and 1ppm both kill the PCM, as will setting it to the maximum value.
    The current version of EFILive limits the ppm to 99% of maximum - so that is no longer an issue.
    The next version of EFILive has a 100 minimum, so soon that will not be an issue.
    The {H0101} is an input and should only be changed when the input changes - i.e. diff and or tire size changes.
    To change the pulses that the PCM outputs, you should be changing: {H0105} and {H0106}.
    Oct 2003
    The problem is, I entered those values using LS1Edit -- so who knows what was actually written to the PCM :lol:
  1. E38 ecm failure
    By shane in forum Gen IV V8 Specific
    Last Post: February 19th, 2010, 11:19 PM
  2. LCD Failure
    By nqcv8 in forum FlashScan V2
    Last Post: January 10th, 2010, 11:58 AM
  3. EFI Failure
    By Telco in forum FlashScan V2
    Last Post: June 10th, 2009, 02:00 PM
  4. speedo failure
    By hymey in forum E37, E38 & E67 PFI ECM's
    Last Post: December 10th, 2008, 05:11 PM
  5. o2 failure
    By southern in forum Gen III V8 Specific
    Last Post: November 5th, 2007, 01:37 PM
